GRIPPY Posted August 3, 2019 Share Posted August 3, 2019 Having removed the gas tank to bleed ABS system,the rubber bushed mounting bolt is nowhere near lining up.Almost a full hole out.Even levering with a piece of wood it is not in line.It was tough to get it out.Is there a trick to this? Link to comment
GRIPPY Posted August 3, 2019 Author Share Posted August 3, 2019 1 hour ago, Hotmop said: Which bike? 94 R1100rs. Link to comment
Michaelr11 Posted August 3, 2019 Share Posted August 3, 2019 The tank has a couple of cutouts that fit into rubber bumpers. Check that your tank is really seated onto those rubber bits. Link to comment
Jim Moore Posted August 4, 2019 Share Posted August 4, 2019 That's never been easy for me. I ended up using a zip tie in that spot on a few different bikes. Link to comment
GRIPPY Posted August 5, 2019 Author Share Posted August 5, 2019 On 8/4/2019 at 12:07 PM, Jim Moore said: That's never been easy for me. I ended up using a zip tie in that spot on a few different bikes. Good to know not just me...I even removed the rubber stops,just the same.I can't identtify what is stopping it moving forward further. Link to comment
