Alba Posted July 30, 2019 Share Posted July 30, 2019 I have removed all the ABS components, connected the front system using a copper connector motorworks sells and bleed both left and right caliper until there are no bubbles from either side. Both calipers are shimmed such the pistons are fully in, the odd thing is with a good squeeze I'm able to get the brake lever almost touching the hand grip. Does this indicate that i still have air in the system even though at the calipers there is no bubbles? Thanks for any guidance. Link to comment
dirtrider Posted July 30, 2019 Share Posted July 30, 2019 17 minutes ago, Alba said: I have removed all the ABS components, connected the front system using a copper connector motorworks sells and bleed both left and right caliper until there are no bubbles from either side. Both calipers are shimmed such the pistons are fully in, the odd thing is with a good squeeze I'm able to get the brake lever almost touching the hand grip. Does this indicate that i still have air in the system even though at the calipers there is no bubbles? Thanks for any guidance. Evening Alba Possibly air in the system but if no air bubbles then probably not. It might be (probably is) just the old rubber brake hoses expanding as the brake pressure increases. If so this is not a good situation as the brake hoses are probably on borrowed time. Link to comment
Alba Posted July 30, 2019 Author Share Posted July 30, 2019 reassurance dirtrider, thanks Link to comment
