RTJohn Posted July 29, 2019 Share Posted July 29, 2019 While trying to remove my GPS with the cradle attached, I inadvertently bumped the speedometer needle. I didn't notice until I reinstalled it. I took off on a checkout run and noticed the needle was starting at subzero. At 75mph on my GPS, the speedometer said 60mph. I went through the exercise of removing it all, taking the clear weather cover off, pushing the needle to zero, and reassembling it all. I took off on another checkout run and the same thing happened. WTF? Any ideas other than taking it to Burbank BMW? Link to comment
Pappy35 Posted July 29, 2019 Share Posted July 29, 2019 What you don't mention is how the needle was exposed in the first place. I have a '13 and the GPS is mounted to a crossbar above the instruments between the windshield and the fairing. Can you post a picture of your installation? Without it there's not much anyone can do to help. Link to comment
RTJohn Posted July 29, 2019 Author Share Posted July 29, 2019 Long story, the cradle won't release the GPS, a Nav V. I had to take the GPS with the stuck cradle off. I couldn't get the cords out without removing the instrument cover and the clear weather cover. Thats when the needle got bumped. Link to comment
dirtrider Posted July 29, 2019 Share Posted July 29, 2019 1 hour ago, RTJohn said: Long story, the cradle won't release the GPS, a Nav V. I had to take the GPS with the stuck cradle off. I couldn't get the cords out without removing the instrument cover and the clear weather cover. Thats when the needle got bumped. Evening John No way to know what got knocked out of adjustment or alignment but that needle sort of floats with the armature spindle so possibly you bent the needle. In any case that speedometer cluster costs over $1200.00 new plus programming so you probably don't want to mess with it unless you know exactly what do & what it needs. Even the BMW dealer wouldn't be my first choice as they usually just replace things like that. If you have a GOOD speedometer repair shop in your area that would probably be my first choice as they deal with similar things weekly. The usually repair not replace. Link to comment
Skywagon Posted July 30, 2019 Share Posted July 30, 2019 try palo alto speedometer repair. http://www.paspeedo.com/ Not sure if they can help this vintage but they have helped me before. See the section for BMW motorcycles. Link to comment
