bmwdavid Posted July 24, 2019 Share Posted July 24, 2019 Sent my bike in for 600 mile service. 2016 R1200RT with 600 miles. Dealer says even though it has 600 miles it’s been 2 years(bought as leftover), plus the time it sat at dealer etc... They recommended a brake fluid flush so ABS doesn’t get contaminated. Not knowing better I agreed to have them do it. $150 extra. Link to comment
wbw6cos Posted July 25, 2019 Share Posted July 25, 2019 You would be amazed at the difference between 2 year old fluid and fresh. The color on the old fluid should be noticeably darker, although you could ask the Service Mgr to save you a sample to compare. Moisture is the biggest culprit, which tends to be present from condensation (temp differences) unless it sat in the a/c controlled showroom the whole time. Either way, you cannot go wrong with flushing it. On my C with ABS II, I do it annually . I just got the new RT in January, so that will be done (by the dealer) per my request; I do not know where that lines up in the service schedule intervals, but it will be done every year. (Perhaps I should go read the Owner's Maintnenance manual.) Cheers, 1 Link to comment
bmwdavid Posted July 25, 2019 Author Share Posted July 25, 2019 It’s a reputable dealer and I’m thinking it was a good choice to change it. They also said the battery was reading 12.3 but said I should put it on the charger and see how it holds up. Link to comment
Skywagon Posted July 25, 2019 Share Posted July 25, 2019 I change my fluid every year. It's super easy and traditional on the wet heads. It was a royal PIA on the 1150's. You can change front and rear fluid in about 30 minutes. I agree with the dealer to change it after 2 years, but...$150 seems high, but probably market/book pricing. Learn to do it yourself as it is rewarding and a heck of a lot cheaper. A pint of fluid is less that $10. Link to comment
Paul4450 Posted July 25, 2019 Share Posted July 25, 2019 I installed speed bleeders to make the task very easy. The only cost $7.50 each plus shipping at speedbleeder.com. It takes 3 different sizes, if I remember correctly. A GS911 is needed to flush the ABS circuit. 1 Link to comment
LAF Posted July 25, 2019 Share Posted July 25, 2019 6 hours ago, Paul4450 said: I installed speed bleeders to make the task very easy. The only cost $7.50 each plus shipping at speedbleeder.com. It takes 3 different sizes, if I remember correctly. A GS911 is needed to flush the ABS circuit. Yes three different sizes. Cant figure that out? Two I can see as the rear is a bit smaller sized caliper. Speed bleeders make it easy but a IV bag and hose works just as well. One kink in the tube and it fills with fluid and it cant draw air even on a regular bleeder. Back in the day we used a jar and fish air line tubing pushed the hose to the bottom with a bit of fluid in it and it cant draw air. While it is true a GS-911 will vibrate the ABS unit by making it turn on and off helping to vibrate the air out of the unit and open the abs valves. However not having that would not stop me from doing it at home for like 15 bucks with the IV bag from Speed Bleeders. If you must after the change then go take it out on some gravel and make the ABS kick in and you have just flushed the ABS unit. No speed bleeders and no GS-911 needed and a very overlooked maintenance that is very simple to do. Link to comment
strataj Posted July 25, 2019 Share Posted July 25, 2019 Yes Lee three different size. http://www.speedbleeder.com/Motorcycle Sizes.htm#BMW I put speed bleeders on at my first change, I helped Speed Bleeders with sizing (great folks). Just did a brake service, it takes no time at all and it's a one person job. Jay Link to comment
AndyS Posted July 25, 2019 Share Posted July 25, 2019 SB8125L right SB6100 left SB1010S rear Most strange. Link to comment
Oldrider51 Posted July 25, 2019 Share Posted July 25, 2019 Thanks for the info on the Speed Bleeders. What brake fluid is being used for this service? I use Pentosin DOT4 LV for my GTI and 04 R1100S ABS. has anyone come up with a pressure bleeder for the LC series? Link to comment
strataj Posted July 25, 2019 Share Posted July 25, 2019 28 minutes ago, 041100S said: Thanks for the info on the Speed Bleeders. What brake fluid is being used for this service? I use Pentosin DOT4 LV for my GTI and 04 R1100S ABS. has anyone come up with a pressure bleeder for the LC series? I get a bottle of Prestone Dot 4 at Wal Mart. No need to pressure bleed, simple and easy to pump the lever/peddle with the speed bleeder open just a little. Just keep checking to make sure you keep fluid up so you don't go dry and suck air into the line. Jay Link to comment
Skywagon Posted July 25, 2019 Share Posted July 25, 2019 one of the tricks you can do to keep brake fluid from squirting out of the top of your master when you squeeze the lever is put a razor blade over the hole. As you know brake fluid is one heck of a paint remover so be sure really cover the painted surfaces. Link to comment
Bill_Walker Posted July 26, 2019 Share Posted July 26, 2019 3 hours ago, Skywagon said: one of the tricks you can do to keep brake fluid from squirting out of the top of your master when you squeeze the lever is put a razor blade over the hole. As you know brake fluid is one heck of a paint remover so be sure really cover the painted surfaces. Yep. Just don't forget to remove the razor blade when you're done! Link to comment
JamesW Posted July 26, 2019 Share Posted July 26, 2019 Drop in a quarter. It's heavier and probably easier to remove. Link to comment
PadG Posted July 27, 2019 Share Posted July 27, 2019 You guys must be really pumping the handle to get the master cylinder squirting up! Never had that happening to me. Link to comment
John Posted August 3, 2019 Share Posted August 3, 2019 I wouldn't put anything in the reservoir to stop splash back of fluid. That's just another means of introducing a contaminant to the fluid. I just loosely fit the cap (and have done so since the 80's). Keep it simple Link to comment
Pappy35 Posted August 4, 2019 Share Posted August 4, 2019 1 hour ago, John said: I wouldn't put anything in the reservoir to stop splash back of fluid. That's just another means of introducing a contaminant to the fluid. I just loosely fit the cap (and have done so since the 80's). Keep it simple Agree completely. I just place the cap back on. There's not enough blowback pressure to pop it off. That or just let the handle out slowly after pumping. Link to comment
