Original RT tool kit.
kruuuzn
Ok, I'm gonna risk looking foolish for asking this, and probably feel MORE foolish when I get an answer, but what the heck are these tools for?
I believe the one on the right (larger of the two) is an extension to slip over the rear wheel lug nuts for increased torque.
RPG
18 minutes ago, kruuuzn said:
Oh ya! Extension for the lug wrench.
I wonder what the flat end does?
Evening kruuuzn
It should be in your owners manual under  "tools"--
The Fabricator
Flat end is for more extension by inserting the shock spring adjusting tool handle.  This tool has a 5" long flat handle with a C shaped end to engage the shock spring [your model may not have the shock spring adjustment built onto the shock body].
The tube is a screw driver shaft extension.  One end goes into plastic handle, the screw driver blade goes in the  other end.
