Redman Posted July 15, 2019 Posted July 15, 2019 Clymer manual says to use antisease lubricant on the shaft drive splines. Okay, I can do that. I was expecting to see it say to use moly lube (say, 60%). Any comment??
dirtrider Posted July 15, 2019 Posted July 15, 2019 14 hours ago, Redman said: Clymer manual says to use antisease lubricant on the shaft drive splines. Okay, I can do that. I was expecting to see it say to use moly lube (say, 60%). Any comment?? Morning Redman BMW service manual says to use Staburags NBU 30 PTM on the splines. Added: the BMW 1200RT manual says to use Optimoly TA on the splines (about the same application only later model) . That is also getting difficult to find in the U.S. as I (believe) it has been changed/replaced with Castrol Molub-Alloy paste HT.
Redman Posted July 18, 2019 Author Posted July 18, 2019 (edited) On 7/15/2019 at 7:09 AM, dirtrider said: .......... ......... use Optimoly TA on the splines (about the same application only later model) . That is also getting difficult to find in the U.S. as I (believe) it has been changed/replaced with Castrol Molub-Alloy paste HT. Have been searching for info on this Castrol Molub-Alloy paste. Not finding any specification that describes it in any detail. By the name, i suspect is a molly grease. Not finding it available locally, but see the small tube is 32-35 bucks. Wondering what the molly content is. I dont have much left of a Honda MolyLube60 from my experience with drive hub in rear wheel of Suzuki shaft drive bikes. I understand that stuff is now replaced with Honda MolyLube77 in little 2 oz tube that i can get for $25. I understand that the Molly content is 60% and now 77% , meant for high pressure load, like drive splines. At the BMW dealer parts counter the parts guy seemed knowledgeable-experienced, so while I was getting other parts, so I asked "what do you guys use on the drive splines", and he said "the molly grease that can get at about any auto parts store". I was thinking that is the stuff in grease gun tube for $5 that says for brake pads and u-joints, that I understand is fairly low molly content. I looked in a couple autoparts stores and didnt see anything differernt. Any further description-discussion of what sort of lubricant should be used?? Edited July 18, 2019 by Redman reword
dirtrider Posted July 18, 2019 Posted July 18, 2019 1 hour ago, Redman said: Have been searching for info on this Castrol Molub-Alloy paste. Not finding any specification that describes it in any detail. By the name, i suspect is a molly grease. Not finding it available locally, but see the small tube is 32-35 bucks. Wondering what the molly content is. I dont have much left of a Honda MolyLube60 from my experience with drive hub in rear wheel of Suzuki shaft drive bikes. I understand that stuff is now replaced with Honda MolyLube77 in little 2 oz tube that i can get for $25. I understand that the Molly content is 60% and now 77% , meant for high pressure load, like drive splines. At the BMW dealer parts counter the parts guy seemed knowledgeable-experienced, so while I was getting other parts, so I asked "what do you guys use on the drive splines", and he said "the molly grease that can get at about any auto parts store". I was thinking that is the stuff in grease gun tube for $5 that says for brake pads and u-joints, that I understand is fairly low molly content. I looked in a couple autoparts stores and didnt see anything differernt. Any further description-discussion of what sort of lubricant should be used?? Evening Redman I really haven't put much thought into it as I still have some Staburags NBU 30 PTM that I use. It probably doesn't make a lot of difference as the drive shaft to final drive splines don't slide or work so about all the grease has to do is prevent rust & corrosion & not dry up or get displaced. It doesn't seem to need a high pressure lube as those rear splines just don't wear out so some do use the Honda MolyLube60 (personally I wouldn't be afraid of using that). Honda MolyLube60 is pretty good at staying in place once applied. Have you tried your local BMW dealer as some dealers will just give you a bit from their shop supply (especially if they know you or feel sorry for you).
AndyS Posted July 19, 2019 Posted July 19, 2019 Hi Redman, if you really want the Castrol Optimoly TA, have you tried Porsche dealers? I believe it is something they use as well.
Joe Coastie Posted July 19, 2019 Posted July 19, 2019 Have y'all thought about belray assembly lube with moly ?
AnotherLee Posted July 21, 2019 Posted July 21, 2019 How about Beemerboneyard's offering for $8.50? Enduralast 477 Spline Lube, 15 Grams Quote 15 gram container of Enduralast spline lube for use on all transmission, driveshaft, clutch and final drive splines on BMW motorcycles. Specially made with a high moly content (60%), silicone base, and additives to prevent fling off and heat related burn off. Perfect size to lube all splines on your bike one time. N
