Sonor Posted July 1, 2019 Share Posted July 1, 2019 Casters - if they say they are rated for 300 lbs but you need four of them, is that a max load of 1200 lbs when using all four? Or is there some equation of what the load should be? Or reverse it, lets say you have a cabinet that with full load weighs 1000 lbs. will four 300 lb load casters be sufficient? Link to comment
Bud Posted July 1, 2019 Share Posted July 1, 2019 Short answer is yes, 4 would be sufficient. 1 Link to comment
szurszewski Posted July 1, 2019 Share Posted July 1, 2019 You could also do it with one 1000lb caster, but you might notice some stability issues 1 Link to comment
