Postman Posted June 29, 2019 Share Posted June 29, 2019 I am new owner of 2008 1200rt. Discovered today headlights went out. Is it normal for all lamps to go out at same time? Link to comment
Twisties Posted June 29, 2019 Share Posted June 29, 2019 They tend to go in short order. I haven't had them both go out simultaneously, but on our two RTs they often go within a day or two of one another. Link to comment
Postman Posted June 29, 2019 Author Share Posted June 29, 2019 Thank you. Was wondering if it might be something else. Odd to me that all the lamps would not be working. Link to comment
lkraus Posted June 29, 2019 Share Posted June 29, 2019 The low beams don't work until the engine starts - was the engine running when you checked? Not too unusual to lose both low beams at about the same time, but I've never lost a high beam. Are the parking lights working? Turn signals? All those lights work through a single 6-pin connector on the back of the headlight shell, roughly between the high beam and the right side low beam, might have come loose. Link to comment
Postman Posted July 1, 2019 Author Share Posted July 1, 2019 I found problem. It has headlight modulator. Wires worked loose. Link to comment
