Capt'n Posted June 17, 2019 Share Posted June 17, 2019 I started up my 96 R1100RT after a long NH winter and it started faithfully right up as usual. I checked the direction lights, high to low beam and then the emergency flashers. Everything works but then I went to switch off the emergency flashers and they will not stop flashing. I turned off the engine and disconnected the battery. Everything went out as it should but when I reconnected the battery, the flashers came back on and still will not go out. I bypassed the switch and still the flashers stay on. Has anyone every else seen this same issue? Could it be a relay somewhere? Link to comment
dirtrider Posted June 17, 2019 Share Posted June 17, 2019 17 minutes ago, Capt'n said: I started up my 96 R1100RT after a long NH winter and it started faithfully right up as usual. I checked the direction lights, high to low beam and then the emergency flashers. Everything works but then I went to switch off the emergency flashers and they will not stop flashing. I turned off the engine and disconnected the battery. Everything went out as it should but when I reconnected the battery, the flashers came back on and still will not go out. I bypassed the switch and still the flashers stay on. Has anyone every else seen this same issue? Could it be a relay somewhere? Evening Capt'n Remove the turn signal flasher relay to see if they quit (in the fuse box on R/H end of center row) If they then quit you will have to try & figure out if that flasher relay is the problem or if it is something external (like emergency flasher switch). Link to comment
Capt'n Posted June 17, 2019 Author Share Posted June 17, 2019 Dirtrider, Many thanks and i will go remove the relay and let you know. Capt'n Link to comment
spacewrench Posted June 18, 2019 Share Posted June 18, 2019 (edited) If you figure out that it's the relay, I put one from my R1100S up on fleaBay the other day. I probably underpriced it, since there's other ones selling for ~$50. If I'd known an actual rider needed it, I'd probably have just mailed it out, but if it's what you need, at least you can get it a little cheaper than the regular eBay price.Auction here. Actually, I just realized I set the Buy It Now price at $20. So I think you can get it for that and not screw around with trying to outbid somebody else. Edited June 18, 2019 by spacewrench Extra info Link to comment
