joeb Posted June 13, 2019 Share Posted June 13, 2019 Hi all. It's been a while since I bled the brakes. 03 1150rt .I have the procedure on my phone to review but before I delve into it, a question. My brakes do the typical wheeze sound but lately I've noticed a squeak , like a pulley. Is it possible the fluid level could be low in the pump reservoir? Can I open the filler caps and check or will that introduce air to system ? The brakes work great but I am a little paranoid about failure after reading all the gloom and doom . Thanks much Link to comment
dirtrider Posted June 13, 2019 Share Posted June 13, 2019 32 minutes ago, joeb said: Hi all. It's been a while since I bled the brakes. 03 1150rt .I have the procedure on my phone to review but before I delve into it, a question. My brakes do the typical wheeze sound but lately I've noticed a squeak , like a pulley. Is it possible the fluid level could be low in the pump reservoir? Can I open the filler caps and check or will that introduce air to system ? The brakes work great but I am a little paranoid about failure after reading all the gloom and doom . Thanks much Afternoon Joeb Can you explain the squeak in a bit more detail? As a rule if you are low on brake fluid in the servo part of the system the dash brake light will illuminate. Might be your alternator belt squealing due the servo pump added electrical load. Can you tell exactly where the squeak is coming from on the bike? Link to comment
joeb Posted June 13, 2019 Author Share Posted June 13, 2019 It sounds like a pulley and near the front of engine.the reason i even thought brskes is bcause it goes away when i squeeze the brake lever. Supppse ot could be coincidence. No fault indications on display. Think ill check the belt. Link to comment
dirtrider Posted June 13, 2019 Share Posted June 13, 2019 7 minutes ago, joeb said: It sounds like a pulley and near the front of engine.the reason i even thought brskes is bcause it goes away when i squeeze the brake lever. Supppse ot could be coincidence. No fault indications on display. Think ill check the belt. Afternoon Joeb So the noise is there with engine running without using the brakes but goes away when you apply the brakes? That does sound more like loose or slipping belt than a brake issue. Link to comment
joeb Posted June 13, 2019 Author Share Posted June 13, 2019 Thanks , ill check out the belt. About the belt, I've seen it replaced without loosening the alternator by forcing it over the pulley. Is this legit or will it damage something ? Link to comment
dirtrider Posted June 13, 2019 Share Posted June 13, 2019 Just now, joeb said: Thanks , ill check out the belt. About the belt, I've seen it replaced without loosening the alternator by forcing it over the pulley. Is this legit or will it damage something ? Afternoon Joeb Yes, no, maybe so-- It depends on the belt, if the elastomer belt then you can sometimes rotate it over the pulley, if a poly-v belt then not a chance. It can also depend of if your alternator spacing to the lower pulley is correct. I have seen a number of belt issues on the 1150 bikes when someone in the past has installed the elastomer belt using the 1/4 twist method, or used the torque the adjustment bolt method. (both incorrect for an elastomer belt) The proper way to install & adjust an elastomer belt is to do it by correct upper/lower pulley spacing. Link to comment
joeb Posted June 13, 2019 Author Share Posted June 13, 2019 If I remember correctly from the last time I put a belt on, the manual said to use a specific torque setting on the alternator adjust bolt. I could never figure how to get a torque wrench on that bolt, so I just went with belt tension that felt correct. I'll have to see if my HAYNES manual Has the spacing spec. Thanks for the info. Link to comment
dirtrider Posted June 13, 2019 Share Posted June 13, 2019 25 minutes ago, joeb said: If I remember correctly from the last time I put a belt on, the manual said to use a specific torque setting on the alternator adjust bolt. I could never figure how to get a torque wrench on that bolt, so I just went with belt tension that felt correct. I'll have to see if my HAYNES manual Has the spacing spec. Thanks for the info. Afternoon Joeb What belt did you install? The elastomer or the poly-v? ---- Makes a BIG difference on how you adjust it. The 2003 1150RT is a strange animal when it comes to belts. The early 2003 came with a non-free-wheeling alternator pulley & poly-v belt, the late 2003 1150RT came with a free-wheeling alternator pulley & the elastomer belt, a few came with the free-wheeling pulley & the poly-v belt that was supposed to be changed to the elastomer belt at first belt change. It all boils down to (IF) the bike has the free-wheeling alternator pulley. Link to comment
joeb Posted June 13, 2019 Author Share Posted June 13, 2019 Dont know. if it is free wheeling should i be able to spin it easily in one direction? Btw BMW. Way to complicate a belt Link to comment
dirtrider Posted June 13, 2019 Share Posted June 13, 2019 2 minutes ago, joeb said: Dont know. if it is free wheeling should i be able to spin it easily in one direction? Btw BMW. Way to complicate a belt Afternoon Joeb Yes, it will only turn in one direction (will free-wheel in the other direction) The free-wheeling pulley should also have a black plastic cover on the front & if you remove the cover you should be able to see the internal splines in the pulley hub (no hex nut) The standard solid pulley will not have that cover & should have a large hex nut holding the pulley on. Link to comment
joeb Posted June 13, 2019 Author Share Posted June 13, 2019 I dont recall seeing a cover on pulley. Link to comment
