RideSafe
2003 R1150RT Biarritz Blue, 17,690 miles - $4,495
RideSafe
You read that correctly -- Only 17,690 miles; meticulously maintained; ready for the next owner to ride and enjoy.
 $4,495 - Located in Montgomery County, MD
VIN: WB10499A13ZE89741
Purchased in August 2004 from original owner. All service done according to or more frequently than required, including oil and filter, EVO system, transmission and rear drive, and other maintenance (valve adjustment, throttle bodies balanced, wheel balancing, spark plugs, alternator belt, air filter, fuel filter)
Accessories included:
  1. Top case with back rest
  2. Side cases with Standard Lids and City Lids, including quick-remove mounting screws
  3. Corbin leather rider seat and pillion seat
  4. Corbin back rest (installs at rear of rider or pillion seat)
  5. Original BMW "Comfort seat" and pillion seat
  6. Motolights, caliper mounted and switch controlled (see item 7)
  7. European factory light-control switch (right handle)
  8. Bob's Wrist Rest and matching counter-weight
  9. Two-filament front/rear marker lights/turn signals (operates same as a passenger car)
  10. Flashing high-output LED brake light
  11. Two LED "third" brake-light strips mounted on rear of luggage rack
  12. Aeroflow windscreen
  13. Aeroflow headlamp guard
  14. Multivex convex side mirrors
  15. Techlusion R259 TFI (corrects for "too-lean" fuel mixture)
  16. Dowco Weatherall Plus full cover
  17. Garmin Streetpilot III GPS with Touratech mount, wired to electrical system so no batteries required
  18. Deltran Battery Tender Plus
  19. Odyssey AGM battery
  20. PIAA halogen bulbs for low beam, high beam, fog lights
NOTES:
  • The bike was dropped once when the wheels were removed to install new tires. Cosmetic damage to: Right mirror, Right engine guard and valve cover, Lower right body panel, underneath cylinder head. The CycleVIN report shows the bike's clean record since new.
  • The case lids have wear & tear scrapes from being tossed around like suitcases.
  • The factory radio prep kit was removed when the bike was new and includes: Left and right speakers, Antenna, Radio mount for glove box, Wiring harness.
  • TPMS system requires new wheel sensors (or you can ignore the displays error message).
Share this post
Link to post
Share on other sites
RideSafe
Price reduced -- $3,995 or best offer
Share this post
Link to post
RideSafe
Price reduced further -- $2,995
Share this post
Link to post
