Aquabud Posted April 17, 2006 Share Posted April 17, 2006 Does anyone have the REAL story on the charger available so that you can charge the battery through the accessory outlet? Link to comment
steveknapp Posted April 17, 2006 Share Posted April 17, 2006 What are you looking for? It exists. You need to do a magic dance to get it to work. And it's about 3x the cost of a battery tender which can be safely hooked direct to the battery. Link to comment
Pictou Posted April 17, 2006 Share Posted April 17, 2006 I am using a battery tender hooked up straight to the battery without any issues. Link to comment
skyking44 Posted April 17, 2006 Share Posted April 17, 2006 I use the one recommended by BMW (Grey) Just plug it into the accessory plug turn on the key, wait for self-test of bike, then turn off key. For me, it is easier than removing the seat,hooking up the positive/negative then removing the positive/negative and replacing the seat.Where do you store the seat while it is being charged? If there are any issues with the battery or Can-bus during warranty, the dealer cannot say it was because you used the wrong charger. Link to comment
R4ND0M_AX3 Posted April 17, 2006 Share Posted April 17, 2006 1. key on 2. connect charger to bike 3. apply power to charger 4. Key off The guys that use a charger directly to the battery might have a pre-wired connector in a spot that is easier to get to than going to the battery directly. Link to comment
RFW Posted April 17, 2006 Share Posted April 17, 2006 I use the one recommended by BMW (Grey) Just plug it into the accessory plug turn on the key, wait for self-test of bike, then turn off key. For me, it is easier than removing the seat,hooking up the positive/negative then removing the positive/negative and replacing the seat.Where do you store the seat while it is being charged? If there are any issues with the battery or Can-bus during warranty, the dealer cannot say it was because you used the wrong charger. Yikes!... if this isn't an example of technological overkill, I don't know what is! All this just to do exactly the same thing as connecting a charger direct to the battery. Seems to me that it is just as easy to wire in a plug to the battery, once, and after that all you need to do is plug in the charger. Bob. Link to comment
steveknapp Posted April 17, 2006 Share Posted April 17, 2006 The guys that use a charger directly to the battery might have a pre-wired connector in a spot that is easier to get to than going to the battery directly. Um, ya. Actually if you use heated gear you might want a similar direct connection to the battery. Dare I say one could use the SAME connection? Link to comment
johnlt Posted April 17, 2006 Share Posted April 17, 2006 Many have connected the rear accessory plug directly to the battery (disconnecting it from the bike wiring). This way when you want to use a Battery Tender or air compressor, just plug it in the rear. I plan to install one in that manner when I get around to it. Link to comment
