Hornhonker Posted April 17, 2006 Share Posted April 17, 2006 Later this week I expect to be picking up a clean looking 99 R1100S (No ABS) from a Suzuki dealer. It has 44,000 Km and the engine does not surge. Everything looks good except there is no service history so I must conclude it probably needs some. What should I get done in order of importance ? Tnx Link to comment
Rob L Posted April 17, 2006 Share Posted April 17, 2006 Change the oil and filter, change trans and rear diff oils, and check the tire and brake pad wear, replace as necessary. Ride the bike for a while and continue to learn from this board about performing your own maintenance. When you have time perform the valve adjustment and synch procedures. When winter returns, do a brake flush. This should get you through the summer! Link to comment
George Posted April 17, 2006 Share Posted April 17, 2006 Maybe check the altenator belt, a quick peek will put your mind at rest, enjoy it Link to comment
Jerry Duke Posted April 17, 2006 Share Posted April 17, 2006 Visit the R1100S site first: http://forums.pelicanparts.com/ Scroll down to BMW R1100S Tech Forum. Great place to find out anything and everything about an R1100S. Link to comment
russell_bynum Posted April 17, 2006 Share Posted April 17, 2006 I would Err on the side of caution and assume that it is well overdue for a major service. I would: Change the oil and filter Check/replace the air filter Change the final drive and transmission oil Change the alternator belt Adjust the valves Sync the throttle bodies flush/bleed the brakes I seem to recall that the S has a hydraulic clutch. If so, flush/bleed the clutch as well. Change the fuel filter That should get the bike to a known-good condition so you don't have to worry about stuff that hasn't been done. If you're in a rush, I'd change the oil/filter, trans oil, final drive oil, and check/adjust the valves. I'd also inspect the brake fluid and if it looks like it needs a change, go ahead and flush while you're in there. Link to comment
