Andy Walks Posted May 21, 2019 Share Posted May 21, 2019 Hi All, My 2012 R1200RT has recently been serviced (main dealer) & seems to have sprung a slight oil leak from a plug I can't identify (please see photo, not my engine but same plug which is red ringed). Looks like it's in the side of the sump, any ideas / suggestions / solutions gratefully received ! Andy W Link to comment
dirtrider Posted May 21, 2019 Share Posted May 21, 2019 1 hour ago, Andy Walks said: Hi All, My 2012 R1200RT has recently been serviced (main dealer) & seems to have sprung a slight oil leak from a plug I can't identify (please see photo, not my engine but same plug which is red ringed). Looks like it's in the side of the sump, any ideas / suggestions / solutions gratefully received ! Andy W Evening Andy Looks like your oil pressure regulator plug is leaking. There is a sealing ring under the plug head. Maybe try tightening the plug (caution don't overtighten) , if that doesn't stop the leak then you will probably have to replace the sealing (caution there is a spring & piston under that plug). Link to comment
Pappy35 Posted May 22, 2019 Share Posted May 22, 2019 According to the BMW repair manual the torque for the oil pressure relief valve is 42 newton-meters (31 ft-lbs). Don't go beyond that as you really don't want to strip the case (remember it's just aluminum and that would really ruin your day). Link to comment
Andy Walks Posted May 22, 2019 Author Share Posted May 22, 2019 Thanks very much for the advice, now tightened to 42NM (moved slightly) so I will wait & see if this cures it, & order a new sealing ring just in-case ! Thanks again for your help Andy W Link to comment
