joeb Posted May 13, 2019 Share Posted May 13, 2019 Changing tires now and figure time to replace valve stems. Considering angled for front , rear not really an issue. So many types available from cheap to pricey . Any thoughts or advice would be appreciated. Thanks. Link to comment
Chris K Posted May 13, 2019 Share Posted May 13, 2019 I would go with the all metal 90 degree. Makes it easier to check the pressure and the metal has a much longer life than the rubber. Link to comment
joeb Posted May 14, 2019 Author Share Posted May 14, 2019 Is the 15mm wheel valve the correct size for an 03 1150rt ? Thanks Link to comment
Michaelr11 Posted May 15, 2019 Share Posted May 15, 2019 13 hours ago, joeb said: Is the 15mm wheel valve the correct size for an 03 1150rt ? Thanks The 1150 RT valve stem, 15 mm, is the same as the 1100RT valve stem. TR412 is the correct item. Link to comment
