MotoNews Posted May 2, 2019 Share Posted May 2, 2019 Published in: Gear With applications ranging from RC8, RC 390, 690 & New 790 Duke, Matris Suspension, distributed exclusively through Rottweiler Performance, offers a comprehensive list of suspension products custom tailored for your KTM. KTM 1290/790 Duke Steering DamperMatris's SD-K Steering Damper is lightyears ahead of your stock unit. With a Twin Tube damping system, an external reservoir for improved heat control, Speed Sensitive progressive dampening & 13 clicks of adjustability, the SD-K puts the control back in your hands. MSRP: $440KTM 1290/790 Duke Racing Steering DamperTitanium body, Twin Tube damping system and 13 clicks of adjustability come standard with every Matris Steering Damper. What sets the Race version apart is their use of a hard chrome coated dampening rod and Ti-Nitride surface treatment for zero friction. MSRP: $555 KTM 790 Duke Rear ShockImprove the handling, stability and comfort level of your KTM 790 Duke with this adjustable drop-in replacement from Matris Suspension. Featuring a hydraulic pre-load adjuster and rebound dampening, unlike the stock shock this unit offers you the ability to tailor your suspension to your riding style and comfort level. MSRP: $670 KTM 690 Duke Racing Rear ShockFrom canyon riding to track days Matris's KTM 690 Duke Racing Shock has what it takes to get you there with confidence. High & low-speed compression adjustments, hydraulic pre-load adjustment & adjustable ride height are some of the key attributes this shock has to offer. MSRP: $1,520KTM RC 390 Racing Rear ShockIf you're looking to improve the performance of your KTM RC 390 then consider Matris Suspension for your handling needs. With multiple shock options and fully adjustable drop-in fork cartridges, Matris has designed their suspension to give you the advantage you've been hunting for. MSRP: $1,095 KTM 1290 Super Duke 25mm Fork Cartridge KitExpect massive improvements over your stock KTM 1290 Super Duke suspension with a set of Matris 25mm Fork Cartridges. Anti-friction lapping, oxidation surface treatment and separate shim stacks are attributes that separate Matris Suspension from the rest. MSRP: $1,335KTM RC8-R 25mm Gas Charged Fork CartridgeThere's always room for improvement when it comes to suspension. Matris's Gas Charged 25mm Fork Cartridges for the RC8 feature a sealed gas charged tank, separate shim stacks, anti-friction lapping & oxidation surface treatment resulting in a confidence inspiring front fork. MSRP: $1,575KTM 790 Duke 25mm Fork Cartridge KitThey may call the KTM 790 Duke the Scalpal but we can all agree that there's room for improvement. That's where Matris Suspension comes in. Fine Italian craftsmanship, anti-friction lapping, custom spring rates and user adjustability are a few advantages you can expect from Matris. MSRP: $1,335 Matris Suspension from Rottweiler Performance.com View the full article Link to comment
