The Rocketman Posted March 19, 2019 Share Posted March 19, 2019 I apologize in advance if this topic has been beaten to death in the past. For 36 years I've always changed my oil hot. Since my bikes have been sitting dormant in the garage for almost 6 months since Thanksgiving, would you still recommend warming up the bikes before changing the oil, considering it’s had ample time to all drain down from the oil coolers? Thanks, Larry Link to comment
dirtrider Posted March 19, 2019 Share Posted March 19, 2019 14 minutes ago, The Rocketman said: I apologize in advance if this topic has been beaten to death in the past. For 36 years I've always changed my oil hot. Since my bikes have been sitting dormant in the garage for almost 6 months since Thanksgiving, would you still recommend warming up the bikes before changing the oil, considering it’s had ample time to all drain down from the oil coolers? Thanks, Larry Morning Larry It's kind of a double edged sword. The up-side is that the oil has obviously drained back (as much as it can) but there is still some oil trapped in areas that can't drain back. Now the downside-- all the gunk & junk that has settled into the bottom of the oil sump over storage time will not drain out with a cold oil change. So that will then mix in with the fresh oil. Cold oil will also take a day or two to ALL drain out of the lower engine area (oil clinging below existing oil level). So pick your poison-- would you rather drain cold oil with a gunk & junk left remaining in the bottom of the oil sump, or would you prefer to drain (relatively clean oil out that that has drained back over time?). The other slight issue (with storage length cold oil change) is that with the oil-drained-back then the engine parts that have drained back over storage have little to no lubrication until the engine is running for a few seconds and building oil pressure. Now add in a fresh oil filter & that after-start run time without oil flow is even longer. (even if you prefill the oil filter it will still take slightly longer to build after-start oil pressure). Link to comment
The Rocketman Posted March 19, 2019 Author Share Posted March 19, 2019 Looks like a warm oil change is the way to go, again. Link to comment
Joe Coastie Posted March 19, 2019 Share Posted March 19, 2019 It's a reason to go for a ride. Warm it up. Link to comment
Skywagon Posted March 19, 2019 Share Posted March 19, 2019 I start most sentences with do what DR says......If it were me, I would ride it for about 45 minutes and bring it up to temp then drain. Why? After sitting that long there is no doubt there is condensation formed in places the oil hasn't been circulated through since you parked it. I would not want that condensation in my new oil.... Link to comment
eddd Posted March 19, 2019 Share Posted March 19, 2019 I've done both. Sometimes it is a pain or impractical to warm things up. Under circumstances like yours I would say it would be impossible to find any real evidence to link any damage or shorten engine life to a cool oil change. Link to comment
The Rocketman Posted March 19, 2019 Author Share Posted March 19, 2019 My thoughts were that all the oil & residue would be so low in the sump after all these months, why recirculate the crap. But DR makes a point that there's garbage below that might not fully drain, and I'd rather not have that floating around and mixing with the new oil. Its really no biggie, except I have to do 3 bikes, and I guess they and I could all use some fresh air time. Link to comment
dirtrider Posted March 19, 2019 Share Posted March 19, 2019 4 minutes ago, The Rocketman said: My thoughts were that all the oil & residue would be so low in the sump after all these months, why recirculate the crap. But DR makes a point that there's garbage below that might not fully drain, and I'd rather not have that floating around and mixing with the new oil. Its really no biggie, except I have to do 3 bikes, and I guess they and I could all use some fresh air time. Afternoon Larry As a common sense controller___ Just about every newer service manual that I have, & that includes (many different makes & models including tractors, automobiles, 4 wheelers, even my generators have a sentence in the first paragraph in the oil change section that says something like (warm engine to operating temperature before changing oil), or (warm engine oil to operating temperature before changing). It's definitely in the BMW motorcycle service manuals. Link to comment
The Rocketman Posted March 19, 2019 Author Share Posted March 19, 2019 If its in the "DR manual" its good enough for me. Thanks again. Link to comment
dirtrider Posted March 19, 2019 Share Posted March 19, 2019 1 hour ago, The Rocketman said: If its in the "DR manual" its good enough for me. Thanks again. Afternoon Larry Actually my internal manual is slightly different. I almost always change my oil & filter before winter storage (especially on equipment that has been used in the very cold fall just before winter). Most motorcycles have exposed oil sumps (some more the others) so in cold damp weather riding the oil has a very difficult time reaching a high enough temperature to purge the moisture out of the crankcase. (BMW boxer riders look at that darn oil temp gauge & figure 'OK' the oil has heated up, they don't realize that it isn't reading oil sump temperature but is just reading the oil temp of the cooling oil before it reaches the oil cooler) Storing any engine with moisture & acids in the oil is a good way to etch a bearing journal. Over the years I have seen a number etched bearing journals due to storage + moisture + acidic oil. Same reason that I could never understand why a motorcycle rider would start their engines in the cold of winter as they will almost never get hot enough running statically in cold weather to get the moisture out of the oil. When I was a young kid (many/many moons ago) I worked a winter on a dairy farm. I used an old (fairly new then) John Deere B with a manure loader to clean the barn & remove piles of XXXX shoveled out of the stalls). Part of my job was to drain the tractor's crankcase of moister (water) buildup every week or two. I would drain at least 2-3 quarts of water out that tractor's oil sump at almost every draining. Now that was a worst case as a dairy barn with cows in it has a winter humidity level of darn near 100%-- But that old JD tractor also had an actual crankcase vent pump to try to keep the crankcase purged. Link to comment
Dave Parry Posted March 21, 2019 Share Posted March 21, 2019 I say definitely warm it up! Link to comment
