jelarner Posted February 16, 2019 Share Posted February 16, 2019 I am doing a spline lube and clutch replacement on my R1100RS. There is a red dot on the drive shaft yoke on end that fits into final drive housing. Any significance ? Link to comment
dirtrider Posted February 16, 2019 Share Posted February 16, 2019 4 minutes ago, jelarner said: I am doing a spline lube and clutch replacement on my R1100RS. There is a red dot on the drive shaft yoke on end that fits into final drive housing. Any significance ? Afternoon Jelarner Not as it relates to the final drive clocking but someone might have used that red dot to mark then re-clock the drive shaft front/rear U joint phasing. The ft/rear U joints on the BMW 1100/1150 don't run at the same working angle so phasing isn't a prime requirement but it is still a good idea to correctly phase them for complimenting working angles. Link to comment
jelarner Posted February 17, 2019 Author Share Posted February 17, 2019 OK DR thank you very much. I was intending to phase the shaft Jerry Link to comment
