Eckhard Grohe Posted April 9, 2006 Share Posted April 9, 2006 I finally bought a BMW tankbag off the internet and am looking at the installation. Does anyone know where to find or have a pdf. of the instructions on how to install it? The issues are: First: the screws at the front are too short if I use any of the washer included. Less than a diameter engagement of the screw. Second: I need to buy the special velcro to attach at the back. Any sources other than BMW? Third: Once I have it, the Velcro, where does it go exactly? Fourth. What about the extra bits of sticky foam? Fifth: What does the skinny shock cord do? Hold on the rain protector? I remember reading abut the bag scuffing the tank and we should add a towel or something to make life easier for the paint. TIA Link to comment
Alan D Posted April 10, 2006 Share Posted April 10, 2006 I can help with number 3... at the bottom of the tank, where the front of the saddle covers the tank, you will find a lip or shelf. You have to remove the seat to see this. I think this is the same velcro as the heavy duty industrial type. I have purchase some like it at a fabric store. The leather flap from the tank bag will attach to the velcro at this point. I think the skinny strap is used for the rain cover like you mentoned and maybe to compress the bag when the extension is attached and the bag is not full. I have never used mine. Good luck Link to comment
Jerry Johnston Posted April 10, 2006 Share Posted April 10, 2006 I just used the scrws that were already in the front - didn't need washers as the braket acks like a washer. You can get some decent velcro at any Radio Shack and when you put the bag in place you'll be able to see where to attach the velcro in back. I Shoe Gooded some of the rubber shelf material to the pads on the bottom of mine to prevent scratching. I don't remember the xtra foam so don't know where it goes and the skinny strap I just streched around the front of mine although around the back you could maybe use it to hold your gloves when refueling? Link to comment
