voodooskin Posted January 31, 2019 Share Posted January 31, 2019 I do a fair amount of my own maintenance but there are things I will take my bike in to have my local dealer's shop do when necessary. What I'd like to have happen when I pick up my bike is to have the mechanic there who worked on it, tell me what they found, what shape the machine is, what to look for on these models etc. I'd like to learn something from someone who looked at my bike in particular, and sees others often, for an honest assesment. Instead what I get is a chance to talk to the BMW certified service manager. This person will read the mechanics notes off the paper to me but one senses has no real clue about the machine. This person is usually different every time I go in (which, admittedly, is infrequent). In my last go here they noted the mechanic advised I replace the mineral oil in the clutch reservoir as it "looked dark". That's not a job the service manual calls out at all. I'll ponder having a mechanic tell me they see better clutch life if the mineral oil is changed, less so when the service manager (who was unaware my R12 had four spark plugs) tells me it's needed for no given reason. In these encounters I generally learn nothing other than the amount I need to pay the shop and whatever notes were written on the service order. This service delivery model "we'll put a buffer between you and our shop and the people in it - pretend there's never any grease" might work for some but it definitely doesn't for me. I realize if there was more work than hands, tearing away to talk to the customer might affect the bottom line however that's not the case at this location. And, not to get too harsh on my local bike shop, my experience with service managers for autos is pretty similar, although with mom and pop shops generally the opposite. I'm curious what your thoughts are. 1 Link to comment
dirtrider Posted January 31, 2019 Share Posted January 31, 2019 2 hours ago, voodooskin said: I do a fair amount of my own maintenance but there are things I will take my bike in to have my local dealer's shop do when necessary. What I'd like to have happen when I pick up my bike is to have the mechanic there who worked on it, tell me what they found, what shape the machine is, what to look for on these models etc. I'd like to learn something from someone who looked at my bike in particular, and sees others often, for an honest assesment. Instead what I get is a chance to talk to the BMW certified service manager. This person will read the mechanics notes off the paper to me but one senses has no real clue about the machine. This person is usually different every time I go in (which, admittedly, is infrequent). In my last go here they noted the mechanic advised I replace the mineral oil in the clutch reservoir as it "looked dark". That's not a job the service manual calls out at all. I'll ponder having a mechanic tell me they see better clutch life if the mineral oil is changed, less so when the service manager (who was unaware my R12 had four spark plugs) tells me it's needed for no given reason. In these encounters I generally learn nothing other than the amount I need to pay the shop and whatever notes were written on the service order. This service delivery model "we'll put a buffer between you and our shop and the people in it - pretend there's never any grease" might work for some but it definitely doesn't for me. I realize if there was more work than hands, tearing away to talk to the customer might affect the bottom line however that's not the case at this location. And, not to get too harsh on my local bike shop, my experience with service managers for autos is pretty similar, although with mom and pop shops generally the opposite. I'm curious what your thoughts are. Morning voodooskin My thoughts are that some shops operate like your experience & others operate on a much more personal & caring level. If you don't like that shop's operating model then find another shop that operates on a more personal level. (some BMW shops have a LOT more friendly atmosphere & make customers feel more welcome) You might also try a face to face with that dealership's owner & express your displeasure with the disconnected feeling that his shop works under. He might be as isolated as you are about the disconnected feeling but HE can change it. As for the dark clutch fluid-- you might heed the technician's warning about changing the hydraulic clutch fluid as dark fluid is usually a sign that it is degrading due to either a slave cylinder grease bleed, or from the internal rubber hydraulic clutch parts. The dark fluid probably won't effect clutch life but could effect clutch hydraulic system life. Change it then if it stays clear (or whatever color it was at install ) then you probably have no real issues, if it turns dark again then that might be indicating a future problem in the hydraulics. Link to comment
Twisties Posted February 1, 2019 Share Posted February 1, 2019 However, due to BMW's excessive limitations on the number of dealers, most of us don't have any reasonable choice in dealers. The next dealer may more than 200 miles away. Having suffered in a single dealer market (and also enjoyed my current one, I'll add - Hanson's is great), I can say that I find it a major drawback to the brand. Link to comment
lkchris Posted February 1, 2019 Share Posted February 1, 2019 So, join your local BMW club ... group feedback is always more powerful than individual feedback. 1 Link to comment
voodooskin Posted February 2, 2019 Author Share Posted February 2, 2019 Thoughtful replies, much appreciated lkchris, Twisties, dirtrider food for thought! Link to comment
RoadRunner Posted February 12, 2019 Share Posted February 12, 2019 Hey Voodoo, My experience is totally different. In my earlier BMW years, whomever worked on my bike at the dealership and I got info like you did. But for the last 8 years or so, I ask for a particular Master Tech, that's who my appt is with. He knows me by site (and by bike) and I always go back and chat with him if I have any concerns or want to know what he found. (Sometimes I leave notes on my bike so I don't forget to tell him something.) I also have his cell number (but try not to use it). If he has to call off or has a family emergency and can't do my service (has happened) the manager is supposed to call me and see if I want another tech or reschedule. In my opinion this is how it's supposed to work. Not to suggest I haven't had any issues....my dealership and gone through a few service managers in the past few years....when I have an issue I go chat with the GM and tell him what happened. My friends now do the same....they've always made it right. Tell them what you as a customer need. If they can't accommodate you, then you know where you stand. Link to comment
Red Posted February 12, 2019 Share Posted February 12, 2019 "If you don't like that shop's operating model then find another shop that operates on a more personal level. (some BMW shops have a LOT more friendly atmosphere & make customers feel more welcome)" Dirtrider, Twisties is spot on. Going to the next closest dealer is not a viable option for many. My closest dealer is 185 miles one way. Next closest 265 and on the other side of the Cascade Mtn Range. Next closest 400. Link to comment
dirtrider Posted February 12, 2019 Share Posted February 12, 2019 6 hours ago, Red said: "If you don't like that shop's operating model then find another shop that operates on a more personal level. (some BMW shops have a LOT more friendly atmosphere & make customers feel more welcome)" Dirtrider, Twisties is spot on. Going to the next closest dealer is not a viable option for many. My closest dealer is 185 miles one way. Next closest 265 and on the other side of the Cascade Mtn Range. Next closest 400. Morning Red With next dealer at 265 miles you do have a choice, not an easy choice & it would be way more difficult but still a choice. So if you aren't happy with the closest dealer you either find another (might not be as convenient for you), or use an independent shop near home (won't work for warranty work though) , or do the service yourself (again, probably won't work for warranty work), or try my other suggestion of: "try a face to face with the dealership's owner (or general manager) & express your displeasure with the disconnected feeling that his shop works under. The owner might be as isolated as you are about the disconnected feeling but HE can change it". It is a shame that some BMW dealers are extremely customer unfriendly but such is life so the rider either puts up with the dealers crap, or tries to get the dealer to change it's customer involvement, or finds another shop that is more to his/her liking. Link to comment
tallman Posted February 18, 2019 Share Posted February 18, 2019 It used to be that any "Certification" came from the employee attending an official BMW school. This was an expensive output for the dealership. But. Things were learned. So, any "Service Manager" unfamiliar with the # of plugs in an R12 either didn't go to school, forgot, or doesn't give a damn. Sad. Certifications earned were displayed. Link to comment
lkchris Posted March 23, 2019 Share Posted March 23, 2019 On 2/1/2019 at 9:49 AM, Twisties said: However, due to BMW's excessive limitations on the number of dealers, most of us don't have any reasonable choice in dealers. The next dealer may more than 200 miles away. Having suffered in a single dealer market (and also enjoyed my current one, I'll add - Hanson's is great), I can say that I find it a major drawback to the brand. I think "excessive limitations on the number of dealers" is fantasy. They probably aren't going to give a dealership to someone in a location where it's obvious they will fail. And they aren't going to lower showroom standards for someone that can't afford it. The only real limitations are territory and owner experience and financial ability Link to comment
Sonor Posted May 2, 2019 Share Posted May 2, 2019 One thing I would like to mention here, is I love the customer experience at Disney World in Florida. Their instruction to all new employees is their first responsibility is to the customer, second is to their team, third to management. They also preach, if you supply the customer with the best vacation they have had they will be back. I bring this up as those two truths should be standard in the service industry. Also, I wish more service providers would send their management to the Disney Institute for training on how to do customer service. All of that said, I have two Beemer dealers that are about equal distance (in opposite directions) from my house. One has had a personal change that helped them to become the one dealer I will go to. The other always made me feel when I was leaving like I had just been had (in some manner or fashion) either lied to, taken advantage of, or generally ripped off. I have recently heard that the second dealer has again changed ownership so we will see if improvements happened. But neither of these dealers have ever made me feel like it was the best place to ______ for my BMW and that resulted in me rarely using them. Link to comment
John Ranalletta Posted May 2, 2019 Share Posted May 2, 2019 The big challenge with service advisors in the vehicle service industry is how they're paid. If they get a salary and their goal is to make customer feel they're treated well, it works. In the real world, a large fraction of their income is commission on what they are able to get customers to buy. Link to comment
LOU Posted May 19, 2019 Share Posted May 19, 2019 I've owned several BMWs, the latest being a R1200RT before that a R1200GS, K1200RS, K1100RS, R1200R, R1100RS. I've had the best experiences with the service department at A&S BMW in Roseville, CA (same goes for the parts dept). Ditto for both at San Jose BMW and Sierra BMW in Sparks, NV. Excellent customer service at both. Link to comment
Bud Posted May 21, 2019 Share Posted May 21, 2019 My experience with Gateway BMW in St. Louis has always been positive! Link to comment
lkchris Posted May 29, 2019 Share Posted May 29, 2019 On of the many cool things about being a member of your local BMW club is that you can maximize your influence on your dealer. Our dealer will invite a group back to the shop for a "tech day" on some topic. They'll provide the donuts. When you're friends, the transactions work lots better. Link to comment
Bud Posted July 15, 2019 Share Posted July 15, 2019 To expand on my experience with Gateway in St. Louis. I recently had an accident with my R 1200 GS that has a sidecar attached. Due to their insurance coverage policy, they won't work on sidecar rigs or bikes that have had sidecars attached. BUT Shannon, the service manager called some other dealers on my behalf. They also had the same insurance liability concerns. He then called Hannigan to see if they would do the bike repairs as well as the sidecar related issues. They will. Shannon didn't have to do any of that. He did it because he cares about his customers. Can not ask for more. 3 Link to comment
voodooskin Posted November 10, 2019 Author Share Posted November 10, 2019 A minor followup: reading some comments above and thinking about the recommendation to change out the clutch hydraulic fluid, I went ahead and ordered some mineral oil and did it a month or two after the dealer visit. Fairly easy job. In doing so I discovered that the rear brake pedal was not even close to finger tight, it was barely threaded on a turn or two; tons of slop in every direction. I'm sure that's how it left the shop as they had worked on the final drive seals, I'm sure the brake comes off to remove the FD. No other issues found but not good form to let a bike leave the shop with a brake pedal ready to depart the bike. Admittedly, I rode it like this w/o noticing in all that time, but I rarely use the rear brake, I rely on the linked braking I get when using the front brake and almost never engage the rear brake unless there's gravel or some other condition that warrants rear braking only. So now not only do I not like the service manager setup, I don't trust the shop. Guess I'm going indy or driving 2 hours to the next BMW shop next time around. Thanks for the helpful comments y'all Link to comment
taylor1 Posted November 10, 2019 Share Posted November 10, 2019 It's funny that Sonar mentioned the Disney World model. I work for a ferry system that was awarded a contract for the National Park System , Being this was a new company, 6 years ago, we had a lot of employee management meetings. The owner went to Florida and met with Disney big wigs to get a clear understanding of their goals. Our owner told us that the customers should always leave with the feeling that they had an experience of a lifetime, and by achieving that, everything else will fall into place. Link to comment
