boxerguy
2009 R1200RT Left Hand ASC Switch
boxerguy
Couldn't find any info on this anywhere...So here Goes! I recently purchased a 2009 R1200RT that has an ASC Switch added to the other standard
switches on the Left side(Cruise, Horn, Windshield,Headlight,and left turn signal).
Both the Left and right control levers were in a bad spot for me, so I set out to adjusting them. I successfully adjusted the Right side with the help of
my Clymer manual. The manual does not show the removal of that ASC Module add on to the Left Side, and I've played with the damn thing for hours
now trying to get it off so I can access the last screw to remove the front of the rest of the switches ..The module is quite loose but doesn't want to
come off...I suspect it needs to slide one way or another!
Share this post
Link to post
Share on other sites
lkraus
Did you find the #1 Phillips screw this driver is on?
Edited by lkraus
Share this post
Link to post
boxerguy
Larry Thanks, It looks to me that is probably the only one I didn't remove...Your photos are great and really pin point the spot well...
Neatly hidden underneath the Clutch Master Cylinder...I will check for that in the Daylight tomorrow...I let you know how things go
tomorrow evening!
Again Thanks, after the first couple of wasted hours, I probably should have queried the forum!
Share this post
Link to post
boxerguy
Larry
Thanks very much for the very concise, informative photos...This morning in the daylight I went right to that spot where you pointed out that elusive #1 Phillips screw.
I was subsequently able to get at the clamping screw and change my lever angle which has been bugging me for a month now! I'm quite surprised that my Clymer
Manual made no mention of the ASC switch. In any event this forum and it's great members have saved the day for me.
Walter
Share this post
Link to post
lkraus
I'm glad that worked for you.
Share this post
Link to post
