tmansk Posted September 15, 2018 Share Posted September 15, 2018 Hello: I replaced the clutch on my 2004 R1150RT; to split the frame I removed the ABS Modulator controller. As I am reinstalling the device I read that I should replace the seals (square-section rings) between the brake lines and the pressure modulator - the Part # is 34517661591. And there is a warning to always fit new spring clips too. The clips I understand but what do I do with the seals (also known as Gasket Rings)? Thank you tmansk@aol.com Link to comment
GS Addict Posted September 24, 2018 Share Posted September 24, 2018 (edited) I've always reused the rings and clips. Never had an issue. On one bike I was doing R&D on had the Modulator re&re'd at least a dozen times. Check carefully for any weeps after install. Edited September 24, 2018 by GS Addict Link to comment
