Emfour Posted September 10, 2018 Share Posted September 10, 2018 (edited) This is what I found when I removed the fuel pump & sender unit. No fuel level sender, and a wired up fuel pump. Replaced the fuel filter, bike starts fine. No chance to test ride,but what is going on? The previous owner was a clueless clot, but this is just weird. Edited September 10, 2018 by Emfour Link to comment
Dennis Andress Posted September 10, 2018 Share Posted September 10, 2018 Nothing wrong with a little safety wire holding things together... Link to comment
Claudio Posted September 10, 2018 Share Posted September 10, 2018 Strange indeed. The assembly is typically a press/friction fit so I guess the previous owner felt it was feeling a bit loose and rather than replace it with a new one, he went for the equivalent of duct tape. It doesn't seem very effective or reliable and would be prone to vibrate off in my opinion. Reminds me of home construction where some builders believe "what is hidden in the wall or cieling is always fine when you don't know its there". Link to comment
Emfour Posted September 10, 2018 Author Share Posted September 10, 2018 (edited) The fuel pump was replaced at one time, thought I saw a 2010 date on it. The fuel filter looks original. Pulling the tank and changing the pump is a pain, why not do the filter? Edited September 10, 2018 by Emfour Link to comment
duckbubbles Posted September 10, 2018 Share Posted September 10, 2018 It also appears that the wiring was replaced at some time. The soy based wires deteriorate over time and the insulation crumbles. The aftermarket fuel pump replacement is smaller than the original if you don't get the original. The safety wire will hold up just fine in fuel. Frank Link to comment
dirtrider Posted September 10, 2018 Share Posted September 10, 2018 This is what I found when I removed the fuel pump & sender unit. No fuel level sender, and a wired up fuel pump. Replaced the fuel filter, bike starts fine. No chance to test ride,but what is going on? The previous owner was a clueless clot, but this is just weird. Morning Emfour It looks like the pump rubber isolator is missing (goes between bottom of pump & the support bracket. You also might want to replace those worm-gear hose clamps as those are not high pressure FI rated. Over time those hose clamps will dig into the rubber hose, loosen up, then the hose will pop off (usually far from home & in the middle of the night). If that happens then it is a definite walk-home. Link to comment
