Nobrakes Posted August 17, 2018 Share Posted August 17, 2018 Changing out OEM rear brake pads with EBC pads in 2017 R1200RT. So I go to change out my rear brake pads. I got the old ones off, no problem.. opened my new EBC pkg and discovered there were 2 identical pads shipped to me as a set. EBC mistakenly packaged them. Beemer boneyard is sending me a new set. My question is; do I transfer the soft padded material on back of the OEM pads to the back of EBC pads or is that just a Brembo OEM thing.? Link to comment
dirtrider Posted August 17, 2018 Share Posted August 17, 2018 Changing out OEM rear brake pads with EBC pads in 2017 R1200RT. So I go to change out my rear brake pads. I got the old ones off, no problem.. opened my new EBC pkg and discovered there were 2 identical pads shipped to me as a set. EBC mistakenly packaged them. Beemer boneyard is sending me a new set. My question is; do I transfer the soft padded material on back of the OEM pads to the back of EBC pads or is that just a Brembo OEM thing.? Afternoon Nobrakes THAT, is a darn good question-- A while back I E-Mailed EBC about that very question & here is what they sent me back---- "Pads must be installed with friction material against disc rotor and metal backing plate towards piston" Da, I guess I should thank them as I probably wouldn't have figured that out without their help!!! As a rule (not cast in stone though) if the pad backing anti-squeal is listed as a separate item in the OEM parts book then transfer it over to the new pads (unless the new pads come with instructions to not do that). If the anti-squeal backing is not listed separately then it usually stays with the old removed pads. Link to comment
Nobrakes Posted August 17, 2018 Author Share Posted August 17, 2018 Thanks dirtrider! 😂 I can't believe EBC told you to put the pads's friction material against the rotor. 😂 Link to comment
