Pappy35 Posted April 17, 2018 Share Posted April 17, 2018 Any get this fault with a GS-911? Error: Attempting to connect to this controller timed out: Possible ReasonsL Killswitch not on Run Module not fitted Signal problem or faulty wiring I just got it and it worked fine the first time I used it but now it won't connect. Any ideas? I tried posting a question to their support forum but that site if horribly unstable. I keep getting Internal Server Errors and even when it did finally post the image wasn't attached. PS - This is for a 2013 RT. I did connect to it fine when I first got the 911, registered it, read data from the bike etc. Just completed a 6k service and was trying to read and clear faults when this issue cropped-up. Link to comment
Pappy35 Posted April 18, 2018 Author Share Posted April 18, 2018 I took the connector (receptacle) off the bike and found a couple of loose pins. Looks someone was messing with it or it was bad from OEM. Regardless, I recrimped them and now it works perfectly. Thanks for the suggestions fellas. Link to comment
