BMWSportTouring
Whooosh
Clear Flat 13mmx8mmx.5mm Washers??
Whooosh
Both my RT and my GS come back from the dealer missing many of these (nearly invisible) little washers under the body panel screws. I'm replacing the air cleaner on the RT, which means removing and reinstalling most of the body panels, so it occurs to me, "Why not try to find replacement washers?!"
Any ideas, anyone found a good source?
Thanks,
Tom
Share this post
Link to post
Share on other sites
Charles Elms
Try McMaster-Carr, they usually have anything you need.
Share this post
Link to post
dirtrider
Thanks,
Tom
Afternoon Whooosh
Yes, count up the number that you are missing then call that darn dealer & have them mail you the missing washers that THEY forgot to reinstall.
If the service manager gives you crap then ask to speak to the dealer owner directly (insist).
If you really don't want to go that way then try a local hardware store as they usually have different plastic washers, or try Lowes as the usually have a couple of pull out drawers with smaller plastic washers.
Share this post
Link to post
Whooosh
Thanks, guys! I'll give all three of those solutions a shot, including the dealer!! (Good point!)
Share this post
Link to post
Bernie
I be watching to see where you find the washers, as most of mine have been missing when I took delivery from the dealer.
Share this post
Link to post
Whooosh
Well, I tried McMaster-Carr, and the washers for the M5 Screw are too small and the washers for the M8 Screw (for the 8mm shank) are too large. And, my nearest dealer isn't open on Monday. I'll let you know...
Tom
From McMaster-Carr online store....
Pkg
Screw ID OD Thick Hardness Qty Color Polycarbonate Plastic
M2 2.1 4.0 0.4-0.6 Not Rated 212° Rockwell R120 Clear 50 90940A411 $8.25
M3 3.3 8.0 0.7-0.9 Not Rated 212° Rockwell R120 Clear 50 90940A412 9.25
M4 4.5 10.0 0.7-0.9 Not Rated 212° Rockwell R120 Clear 50 90940A413 9.75
M5 5.5 12.0 0.7-0.9 Not Rated 212° Rockwell R120 Clear 50 90940A414 11.00
M6 6.5 13.0 0.9-1.1 Not Rated 212° Rockwell R120 Clear 50 90940A415 13.00
M8 8.5 18.0 1.4-1.8 Not Rated 212° Rockwell R120 Clear 25 90940A416 11.63
M10 10.5 22.0 1.4-1.8 Not Rated 212° Rockwell R120 Clear 10 90940A417 10.35
M12 13.0 24.0 2.2-2.8 Not Rated 212° Rockwell R120 Clear 10 90940A418 10.95
Share this post
Link to post
RTinNC
My local Ace hardware had some that fit near perfect. They were in the aisle with the little bins.
Share this post
Link to post
Joe Frickin' Friday
Anyone tried www.fastenal.com?
Share this post
Link to post
