RoSPA_man Posted March 15, 2018 Share Posted March 15, 2018 Hi Quick question. I can feel a very slight amount of "up and down" play in the fork cross brace ie the handlebars! It's a tiny amount. Taking a really quick look, I see a 21 mm nut underneath the brace which on a quick try, doesn't seem to want to loosen or tighten! Looking at the Microfiche , it looks like the offending item must the the "angular ball bearing" (2) Is this easy to replace? Any heat required? Any gotchas? Do I/ can I attack from above i.e. under the BMW logo in the center of the brace? If yes, it would seem to be straightforward. Sorry about the questions, but I don't have the manual for this camhead (although I suspect it's little different to my Haynes manual for the Oilhead Thanks Link to comment
dirtrider Posted March 15, 2018 Share Posted March 15, 2018 Hi Quick question. I can feel a very slight amount of "up and down" play in the fork cross brace ie the handlebars! It's a tiny amount. Taking a really quick look, I see a 21 mm nut underneath the brace which on a quick try, doesn't seem to want to loosen or tighten! Looking at the , it looks like the offending item must the the "angular ball bearing" Is this easy to replace? Any heat required? Any gotchas? Do I/ can I attack from above i.e. under the BMW logo in the center of the brace? If yes, it would seem to be straightforward. Sorry about the questions, but I don't have the manual for this camhead (although I suspect it's little different to my Haynes manual for the Oilhead Thanks Afternoon Hugh Kind of a pain but definitely doable at home. You need to remove the handlebars unbolt the fork tubes then remove the upper fork bridge (watch the ign switch & antenna ring wiring). Then remove the snap ring retaining the bearing, then heat the fork bridge in the bearing area to 100°c & press or drive the old bearing out. Then reheat the fork bridge to 100°c & press the new bearing in, if you drive it in (not recommended) then do not drive on the center as that transfers the hammer blows through the bearing & can damage it. Link to comment
RoSPA_man Posted May 6, 2018 Author Share Posted May 6, 2018 Hi DR I thought I'd said thanks back in March, but I see I hadn't. So, belatedly, thanks as always - you are a true mine of information! Link to comment
Lester V Posted May 10, 2018 Share Posted May 10, 2018 My .02 cents canuck. I thought my front angular ball bearing last fall was toast. The bike handled very poor, just like the 2007 12gt I owned . Took off the front worn out Michelin pr4 (great tire) and the new rear already worn out dunlop 3 at 3k miles (very bad tire as it cupped on one side etc) New tires, new bike. No ball bearing problem at 65 k miles on my 2011. Yes, I do know what a front bad ball bearing feels like. I had a 2007 that had one. Cheers Link to comment
