BMWSportTouring
Doug 55
R1150RT gas cap "stuck" with suction force / bike quitting
Doug 55
Hi All,
Trying to get my R1150RT back to 100% after it sat for a year :( so I have been doing short test rides and noticed:
(1) the gas cap is "stuck" closed with suction force after riding ... does that indicate a vent line clogged up or?
(2) it was quitting at slow speed in the test rides this afternoon .... maybe due to gas flow problem due to the gas tank apparently being under vacuum?
TIA for any advice!!
Share this post
Link to post
Share on other sites
dirtrider
Hi All,
Evening Doug
Sounds like you either have a plugged evap can or a plugged evap system vent hose, or your tank is vented incorrectly.
If you don't have an evap can then look for a spider or wasp mud plug in the bottom or your tank vent hose (coming out behind the riders R/H foot peg.
If you don't find & repair the problem you will soon have crushed fuel gauge sender tube & fuel gauge that doesn't read correctly.
Share this post
Link to post
szurszewski
The good news is those symptoms sound like signs of the same problem, so it's likely you only have one - relatively simple - thing to fix!
Share this post
Link to post
bewareboy
Doug 55,
Do you know if your bike still has the charcoal canister still installed? If so there seems to be some thoughts that charcoal migration can start to plug the vent lines. If it is still installed, I would pull off your right hand side fairing. You should find just behind and below the fuel tank 2 vent lines each with a union coupling. 1 is for the tank cap water drain and the other is part of the charcoal canister tank vent system. I don't recall with the installation which line is for which vent/drain. My thought is to make a small colored mark on each line on each side of the coupling (i.e. white dot on one line both sides of the union and yellow dot on the other line both sides of its union). This way they don't accidentally get swapped when you split/disconnect them at the union. Alternatively, you can separate each line by itself and then reconnect before moving to the second line. The idea here is to see if this may relieve any negative pressure that might be holding the cap from opening. The cap drain line should just be ambient pressure as I believe that is an open drain for water to follow down to just behind the riders right hand foot peg. The tank vent should go back to the charcoal canister and if that line was plugged this MIGHT relieve the suction... if there is any. If the charcoal canister was removed form the bike previously then both of those 2 vent/drain lines shouldn't maintain any pressure as the are both at ambient pressure and again routed down to just behind the riders right hand foot peg.
The other thought would be to split the fuel supply and return to see if that would relieve negative pressure. If your fuel lines have quick disconnects, once each are separated, then you may need to carefully unseat the self sealing check valve in each half of the supply and return on the tank side. You might get some fuel coming out, but if there is a contained negative pressure in the tank, then I think you would get an initial air inflow into the tank and maybe not any fuel coming out.
I have an 1150RT and removed the charcoal canister a few years ago and have never had any tank venting issues. I did replace all my supply, return and vent lines also and have them color coded to reduce the likelihood of swapping lines around. Once you have the cap open you can check if the lines did get swapped previously by blowing low volume air through them, with the cap drain being the easiest to diagnose. The main thing is to first understand the current system (canister installed or not) and them move on from there. There have been cartoon illustrations of the system originally and if the canister has been removed. From that you can deduce each lines connection points and confirm all is correctly installed. Search the forum for other threads on charcoal canister removal and you should find it.
I am not really sure if a negative pressure can be created to the extent to prevent the tank cap from being opened thought. Other more experienced forum contributors may have better first hand experience and should chime in shortly. Hopefully I haven't given you any bad info or sent you on a wild goose chase.
Thanks and hope you get this figured out relatively simply and quickly.
Share this post
Link to post
Tenorman
doug55,
Simply "Google" R1150RT charcoal canister"...you will find many, many posts on removing or replacing the charcoal canister.
I had this same problem on my 2005 R1150...I've removed mine...it's very easy to re-route the hoses and you can leave the canister on the bike if you wish.
There will be 1 port under each cylinder that you will need to cap with a plug...(you'll see where the vacuum line connects).
Have fun...
Tenorman
Share this post
Link to post
Doug 55
Thanks everyone for the information and advice!!! The solution ended up being disconnecting the charcoal canister; everything works fine now. It was an "interesting" 45 minute ride to the mechanic though: I had to leave the gas gap open to vent and wouldn't-you-know-it had just filled the tank to the very brim :dopeslap:
Share this post
Link to post
