BMWSportTouring
Retired At LAst
Oil Cap Replacement
Retired At LAst
I pryed up the old oil cap holder with o ring No problem
How do I insert the new one. It just wont pop in no matter how hard I push
Whats the trick?
Share this post
Link to post
Share on other sites
AnotherLee
Ret -
Have you tried Tri750's method?
“...a pocket screwdriver and patience will get the plastic base out fine.
Clean the residual oil, new o ring and press down with one thumb while you slowly tuck the oring in with the same screwdriver around the perimeter of the plastic base. Just small bites at a time.
It will work in.
Pretty cold up there?
Edited by TheOtherLee
Share this post
Link to post
SAS
I used a socket the same size as the insert, and tapped it in with a mallet. What size you say?, well I don't remember off hand. I also used some EZ Turn to lube up the "O" ring to ease the installation.
Share this post
Link to post
