BMWSportTouring
Mark C
Question for Dirt Rider
Mark C
Have you ever removed & replaced universal joint on R1200RT ?
Share this post
Link to post
Share on other sites
dirtrider
Morning Mark
Yes, I have done a couple.
First problem is in finding the proper sized U joint (it's not a common sized joint), then cutting the old one out, then cleaning up the yoke cap bores without oversizing the bores, then pressing the new joint/caps in, then spinning shaft in a lathe with dial indicator to center the joint in the yoke, then tack welding washers over the caps in the yoke bores to retain the new U-joint caps. (it's not an easy do-it-yourself project without proper equipment)
Share this post
Link to post
Indy Dave
Mark - did you intend to post this in Hexheads? The way you've framed your question - no insight to the issues you're facing and by limiting your question to just one person, you've kind of negated the point of this website. There are others here who have had universal joint problems and solutions.
Share this post
Link to post
eddd
+1
Share this post
Link to post
AnotherLee
+2 — and, anyone doing a search couldn't tell what this thread was about. You asked an excellent question - it deserves a descriptive title.
Edited by TheOtherLee
Share this post
Link to post
