Bubbadozer Posted July 24, 2017 Share Posted July 24, 2017 (edited) My R1200RS has a owie on the LH blinker that needs to be replaced. I haven't been able to find a schematic on removal of front fairing assembly. i am wondering what all needs to be removed in the process. I think all I need to replace is blinker lens and mount and a small crack in plastic, then probably a trip to paint shop for front fairing to restore bike to pristine looking condition. Edited July 24, 2017 by Bubbadozer Link to comment
AndyS Posted July 24, 2017 Share Posted July 24, 2017 Hi Bubbadozer. Not sure what you mean by an 'owie'. However, you are posting this in the wrong forum. You should re-post it in the releveant Hexhead/camhead/wethead forum. Hopefully an Admin will remove this from the Oilhead forum...unless you can. Link to comment
Michaelr11 Posted July 24, 2017 Share Posted July 24, 2017 Bubba has several other posts in this forum concerning his 1996 R1100RS. The subject line of this post says 1100, so I guess he hit the wrong key when he typed his question. I'm riding an 1100RT so I can't answer his question. Link to comment
tallman Posted July 24, 2017 Share Posted July 24, 2017 Pretty straightforward, make a drawing of bike on cardboard, remove screws and place them thru the cardboard at corresponding points. Here's some on-line links (supposed), I didn't open them. r 1100 rs fairing removal RSL Diagram/parts Hope they help. Link to comment
Bubbadozer Posted July 24, 2017 Author Share Posted July 24, 2017 (edited) I posted in oilhead forum, because that is what I have I thought. 96 R1100RS. I thought hexheads' were the 1200's, but then again I'm a newb. Edited July 24, 2017 by Bubbadozer Link to comment
Sam Taylor Posted July 24, 2017 Share Posted July 24, 2017 I think you want this: http://parts.bmwmotorcycles.com/a/BMW__R1100RS/_51518_5694017/Trim-panel-upper-part-rs/46_0249.html You'll probably need to remove the windshield and trim panels around the instruments too. It's not hard. Link to comment
Bubbadozer Posted July 24, 2017 Author Share Posted July 24, 2017 (edited) Thanks Sam, but I already had that schematic. I can tell from looking at it, that there is a lot more involved to get that front fairing off. Such as (I think) headlight assy, Inst cluster, etc, but I was hoping for a schematic. Thanks for responding. I'm confused about the posting in the wrong location thing though. I dont want to be annoying, just trying to learn about the BMW I recently purchased. Cheers Edited July 24, 2017 by Bubbadozer Link to comment
Bubbadozer Posted July 24, 2017 Author Share Posted July 24, 2017 My BAD! I need to proof read I guess before I post, clearly... I accidentally typed 1200 instead of 1100. Link to comment
Ron L Posted July 25, 2017 Share Posted July 25, 2017 From the factory manual.. • Remove windshield. • Remove side sections of fairing. • Remove inner fairing panel. • Unscrew and remove windshield adjusting shaft. • Detach instrument cluster. • Detach plug connections for flashing turn indicators. • Detach top section of fairing. • Remove headlight. • Remove bracket for windshield. • Remove fairing. • Install in the reverse order of work. Link to comment
Bubbadozer Posted July 25, 2017 Author Share Posted July 25, 2017 (edited) Ron, Thanks so much. I ended up buying a digital copy of the complete service manual and I think I'm set. Only other thing I have to do is either pay $400 to have the Ohlins reconditioned that are leaking or find some OEM that are still serviceable, and I will have a reliable bike. Edited July 25, 2017 by Bubbadozer Link to comment
