Bubbadozer Posted July 5, 2017 Share Posted July 5, 2017 My 96 r1100rs front brake rotors both rattle and move. I'm assuming that the bushings with theC clips are worn out or something. When I Hoover bumps it rattles. The brakes are functioning fine as is the ABS. Am I correct in my assumption that the bushubgs are worn out, and if so, are they replaceable? Thanks for any assistance, Scott Link to comment
AndyS Posted July 5, 2017 Share Posted July 5, 2017 Yes, the bushings do wear out and are readily available. Link to comment
AndyS Posted July 5, 2017 Share Posted July 5, 2017 See http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51680 Diagram 34_0660 - FRONT WHEEL BRAKE Item 2 BMW part # 34112310995 ROLLER WITH SNAP RING @ $8.29 Item 3 BMW part # 34112310088 6 off WASHER @ $2.00 Item 4 BMW part # 34112310089 LOCK RING @ $2.92 I believe our own Dan Cata sells these too at a much more attractive price: http://boxer-upgrades.webs.com/apps/webstore/products/show/3821625 Link to comment
Michaelr11 Posted July 5, 2017 Share Posted July 5, 2017 +1 for the Dan Cata kit. You didn't mention how many miles you've got on that '96 R1100RS. Depending on the miles, it is possible that in addition to the worn bobbins, your rotors are below minimum thickness. Just saying that you might be replacing the bobbins and then still have rotors that need replacing. Link to comment
Bubbadozer Posted July 5, 2017 Author Share Posted July 5, 2017 Do you happen to know what the minimum thickness is for the rotors? Mine is 4.85 mm Link to comment
szurszewski Posted July 5, 2017 Share Posted July 5, 2017 I Believe its 4.0mm. I also believe you can find it stamped on your rotor. Link to comment
Michaelr11 Posted July 6, 2017 Share Posted July 6, 2017 Do you happen to know what the minimum thickness is for the rotors? Mine is 4.85 mm At 4.85 you are fine. Original rotors were 5.0 mm and minimum thickness is 4.5 mm. My RT has 166K miles and the front rotors are at 4.35 mm. I used the Dan Cata kit a while back but now I'm replacing the rotors. Link to comment
Bubbadozer Posted July 6, 2017 Author Share Posted July 6, 2017 (edited) I'm at almost 88k miles. Awesome guys, thx!! I will get the bushings and be good to go. Edited July 6, 2017 by Bubbadozer Link to comment
TimE Posted July 19, 2017 Share Posted July 19, 2017 So is it dangerous if these bushings are loose? I have a 99 w/65K on it and my front disk rattles if I manually wobble it, but have not observed any noise while in motion. Link to comment
Michaelr11 Posted July 20, 2017 Share Posted July 20, 2017 So is it dangerous if these bushings are loose? I have a 99 w/65K on it and my front disk rattles if I manually wobble it, but have not observed any noise while in motion. If you grab the rotor and move it in/out towards the wheel and away from the wheel, you will feel movement and might hear a rattle. This movement - on the axis of the axle - is normal. That is the "float"of a floating rotor. If there is rattle and movement radially, moving the rotor along the rotation of the wheel, that is from wear to the bushings. If the wear is so great that the bushings are loose enough to fall out, then it's dangerous. Otherwise it is mostly annoying. Link to comment
TimE Posted July 21, 2017 Share Posted July 21, 2017 Good to know. Thanks for the clarification on this! Link to comment
