Imgnr Posted May 31, 2017 Share Posted May 31, 2017 (edited) Hi Folks, I feel like a bonehead but I got the new (used) tensioner in and for the life of me, cannot screw it in. Feels the the end of the tensioner should fall into a slot or something but it doesn't. About 1 1/2 inch of the tensioner sticks out and when I push it down and turn it, it's not catching. I also stuck an allen wrench into the hold to see if I could feel an opening but there doesn't seem to be one. Note: I started the bike w/o the tensioner on (took a while to start as you can imagine with no pressure in one cylinder due to the tensioner not being where it should be). Engine spit up about a quart of oil before I realized my mistake. Don't think it should affect anything but thought I should mention it. Thank you! Edit: There's a check valve in the cylinder. If it's been used, there will be hydraulic pressure in there. You need to release it by using a small allen wrench and pushing into the valve. So, problem solved. I tried to delete this issue but the system won't let me. Also, it might help someone else. Edited May 31, 2017 by Imgnr Link to comment
Roger C Posted May 31, 2017 Share Posted May 31, 2017 I just replaced the cam chain tensioner on my RT last week and experienced the same problem you mention. So, I pulled the top part out (very tricky positioning) and put it back in. It fell right in place and I was able to align the threads of the bolt head with my fingers and turn it a couple times before applying a wrench. Don't understand why it would not fit on the first attempt but no worries now. Link to comment
Imgnr Posted May 31, 2017 Author Share Posted May 31, 2017 If you bought a used one like I did, then there is still oil in the piston that needs to be bled out. Link to comment
Roger C Posted May 31, 2017 Share Posted May 31, 2017 If you bought a used one like I did, then there is still oil in the piston that needs to be bled out. Mine was purchased new from Rubber Chicken Racing Garage. I suspect there might be a matching part on the inside of the top chamber which would mate with the piston. The top of the piston is smaller in diameter than the piston and has a flat side on it. Link to comment
dirtrider Posted May 31, 2017 Share Posted May 31, 2017 If you bought a used one like I did, then there is still oil in the piston that needs to be bled out. Mine was purchased new from Rubber Chicken Racing Garage. I suspect there might be a matching part on the inside of the top chamber which would mate with the piston. The top of the piston is smaller in diameter than the piston and has a flat side on it. Evening Roger Nothing inside the upper cylinder chamber that mates with the piston (the piston is just a small piston within a larger piston). The idea of the small piston inside a larger upside down piston is that it holds oil in the upside down outer piston so it can't completely drain back when parked). That trapped oil can make them a pain to install unless drained (even new ones can have some oil in them) Link to comment
