Bikerstrat64 Posted May 29, 2017 Share Posted May 29, 2017 Hello - My first post here - 1996 R1100RT (55K) - After a run, the ABS motor continued to run, even after the ignition was turned off. I've read that it could be the ABS relay. Any suggestions and fixes other than bring it in to a pro? I generally prefer to dig in myself. I'm making a quick fix with connectors from the neg terminal. Thanks! ~ Nash Link to comment
dirtrider Posted May 29, 2017 Share Posted May 29, 2017 Hello - My first post here - 1996 R1100RT (55K) - After a run, the ABS motor continued to run, even after the ignition was turned off. I've read that it could be the ABS relay. Any suggestions and fixes other than bring it in to a pro? I generally prefer to dig in myself. I'm making a quick fix with connectors from the neg terminal. Thanks! ~ Nash Afternoon Bikerstrat64 Top of list would be a failed or contaminated ABS relay (under cover on side of ABS controller)--OR, if the ABS power relay is good then something inside the ABS controller is calling for the motor to run & triggering the relay. Link to comment
Bikerstrat64 Posted May 29, 2017 Author Share Posted May 29, 2017 That's my though also - thanks for the input. :-) Link to comment
farmerboy Posted May 29, 2017 Share Posted May 29, 2017 (edited) There is a guy who tore down a later abs unit on the UK Adv rider forum. Not the same but maybe some useful info there if you can find it... Found it... http://www.ukgser.com/forums/showthread.php/448030-Attempting-to-repair-servo-ABS-unit and my experiences..... http://www.bmbikes.org.uk/Forum/viewtopic.php?f=85&t=24844 Edited May 29, 2017 by farmerboy Link to comment
dirtrider Posted May 29, 2017 Share Posted May 29, 2017 (edited) There is a guy who tore down a later abs unit on the UK Adv rider forum. Not the same but maybe some useful info there if you can find it... Afternoon farmerboy You have a completely different type of ABS system (the OP's 1996 BMW 1100 has the old piston type ABS with an external power relay). Edited May 29, 2017 by dirtrider Link to comment
AnotherLee Posted May 29, 2017 Share Posted May 29, 2017 Once you have ruled out an abs relay problem, check out ModuleMaster . The good news is they rebuild these units. *link* Link to comment
