bulletbill Posted May 27, 2017 Share Posted May 27, 2017 2007 BMW R1200RT canister plugged! I say it is plugged? Had the gas tank hissing when I gassed up? Checked the Canister and it was full of fuel. Beemer bone yard is out of stock and a OEM is around $70. So I took the line from the gas tank (when to the top center of the canister)connected it to the drain line out of the bottom of the canister, plugged the vacuum line that goes to the vale at the top of the canister. Am I OK until I can get a replacement rom Beemer Bone Yard? Link to comment
dirtrider Posted May 27, 2017 Share Posted May 27, 2017 2007 BMW R1200RT canister plugged! I say it is plugged? Had the gas tank hissing when I gassed up? Checked the Canister and it was full of fuel. Beemer bone yard is out of stock and a OEM is around $70. So I took the line from the gas tank (when to the top center of the canister)connected it to the drain line out of the bottom of the canister, plugged the vacuum line that goes to the vale at the top of the canister. Am I OK until I can get a replacement rom Beemer Bone Yard? Evening bulletbill No problem as long as the tank is properly vented to atmosphere. You can basically run it like the forever if you need to. Link to comment
bulletbill Posted May 27, 2017 Author Share Posted May 27, 2017 Thanks DR, I may just run it that way. Then I can be a deplorable and a polluter. HeHe! Link to comment
