NickInSac Posted March 2, 2017 Share Posted March 2, 2017 Windshield won't go down. Interestingly, (or not) the fuel strip seemed to die after a key reset (to check the windscreen motion). I had the fuel strip replaced last year. It didn't work for about the first five minutes of a ride this morning. I looked down and it was working again. But still, not the windscreen. I have the aluminum upper brackets on it. The brackets all look good. I did a search, but I only found that the brackets break. It seems like the GS-911 won't have a code for this. But, I'll check it when I get home tonight. I'm thinking it's the switch. Any other suggestions? TIA Link to comment
NickInSac Posted March 3, 2017 Author Share Posted March 3, 2017 Well. That was fun. Took my big winter screen off after going home with it halfway up. Yah, it looked huge going down the freeway. It still went up. I put moderate pressure on the brackets to push it down and hit the up and down button and suddenly it worked again. I think the switch wasn't making a good contact. I will probably have to either take the switch apart and clean it in the future or replace it. Btw: I have 114k miles on the bike. Link to comment
