Danasor Posted January 13, 2017 Share Posted January 13, 2017 Hello, new member here. I did try the search tool. I have a '16 r1200rt with a 48 liter trunk. My pillion wants arm rests after seeing a K1600. Please share your knowledge, experience, solutions, and aftermarket ideas. I don't want to have to reinvent the wheel. Thanks! Dana Link to comment
tallman Posted January 13, 2017 Share Posted January 13, 2017 There is/was a company, made the Strongrak. online at strongbilt.com link from MOA Marketplace. But, not with the 48L, separate set up. Good luck. Link to comment
TEWKS Posted January 13, 2017 Share Posted January 13, 2017 If you have this top box, you should be able to retrofit the BMW rests from the Exclusive. The box and rack are the same on both bikes I believe. Welcome, you live in a great location! Pat Link to comment
tallman Posted January 13, 2017 Share Posted January 13, 2017 Thanks, Pat. Out of the loop. Link to comment
TEWKS Posted January 13, 2017 Share Posted January 13, 2017 Tim, there may very well be a big gotcha with my theory. But, knowing that I swapped the same top case between the K16 & R12/LC I figure it should work. Probably an expensive prop though! Pat Link to comment
TEWKS Posted January 13, 2017 Share Posted January 13, 2017 Another Possible Option. Pat Link to comment
tallman Posted January 14, 2017 Share Posted January 14, 2017 Smart. We used to be inundated by requests for arm rests like the "LT". Link to comment
Danasor Posted January 15, 2017 Author Share Posted January 15, 2017 Thank you all for the welcome and the links/ideas. I have considered fabricating aluminium rests and attaching them to the 48 liter box, recognizing that they could detach in a crash. Alternately I have thought about making a cradle or frame that attaches to the lower insides of the box, requiring minimal space but adding significant strength. Thoughts? Thanks again, Dana Link to comment
