Rob L Posted December 30, 2016 Share Posted December 30, 2016 Got a couple of days off and decided to prep the bike for next summer's riding season. Step one replace air cleaner. For those of you who have done this you know how long this takes. No wonder the shops charge so much to do the 12,000 mile service. Some German engineer decided to bury the aircleaner under 25 pieces of tupperware (my count). They used 182 screw of various lengths and configurations with at least 14 different kinds of spacer washers (again, my count). The picture shows the ones that I found. The rest remain somewhere in my garage under benches, welders, cabinets, etc. Finally I reached the magic cover that the air filter resides under. It has screws that are 12" long and also requires a pry bar to remove. To further complicate the process they run these screws through a cage looking gizmo that surrounds the filter. I felt like I was breaking it out of jail. Below the filter is a cavern that could have been used to increase the fuel capacity by at least 2 gallons. Did I mention the 2 side tupperware covers that I removed first? They of course both needed surgery because the same German engineer that buried the air filter also designed the retaining tabs that hold these pieces in place at the top. I spent another hour fabricating metal replacement tabs and epoxying them in place. When I took a break, I looked outside. It was already dark and snowing. I guess I'll leave the brake flush, oil change, rear drive fluid change, and valve adjustment for tomorrow. Link to comment
RTinNC Posted December 30, 2016 Share Posted December 30, 2016 Yikes .... Guess coming from my 2006 RT "this isn't Kansas Toto" !! Link to comment
gordiet Posted December 30, 2016 Share Posted December 30, 2016 I did mine recently and it's is truly a PIA to do. When I got to mine it was clean! GT Link to comment
Rob L Posted December 30, 2016 Author Share Posted December 30, 2016 Mine was also pretty clean, but I changed it anyway. After taking the bike this far apart, I won't be doing this again until maybe 60,000 miles. Link to comment
tallman Posted December 30, 2016 Share Posted December 30, 2016 Ever taken an LT apart? Probably the manual your designer followed... Link to comment
narcosis Posted December 30, 2016 Share Posted December 30, 2016 (edited) My air filter was clean too but after the trouble of getting to it, it was going to get changed out. Edited December 30, 2016 by narcosis Link to comment
Bill_Walker Posted December 30, 2016 Share Posted December 30, 2016 Boy, that really makes me want to hold on to my 2004 for a few more years! Changing the air filter means popping off the seat and undoing two screws. Link to comment
RTinNC Posted December 30, 2016 Share Posted December 30, 2016 Boy, that really makes me want to hold on to my 2004 for a few more years! Changing the air filter means popping off the seat and undoing two screws. Yes but you have to check your valves every 6K .... and the RT(w)is every 12K. And pretty sure on the 2004 you did not have the mineral brake clutch fluid. Life is full of trade offs! Link to comment
John in VA Posted December 30, 2016 Share Posted December 30, 2016 ...Below the filter is a cavern that could have been used to increase the fuel capacity by at least 2 gallons. Or perhaps configured as a center glove box big enough to hold an actual pair of gloves? Link to comment
greiffster Posted December 30, 2016 Share Posted December 30, 2016 Boy, that really makes me want to hold on to my 2004 for a few more years! Changing the air filter means popping off the seat and undoing two screws. That should leave you plenty of time for the brake flush. Link to comment
Rob L Posted December 30, 2016 Author Share Posted December 30, 2016 Yeah, I had a 2004 and 2006. You get to take your gas tank off and follow a pita sequence to flush your wizzy brakes That is required every 2 years. I know that I won't revisit my air cleaner for at least 30,000 miles Then there are the 4 spark plugs that you need to change. They are made of solid gold....or at least priced that way. Link to comment
strataj Posted December 30, 2016 Share Posted December 30, 2016 (edited) The wizzy brakes on my 02R1150RT took a lot of time and I did mine every year, the air filter got dirty it either needed a good cleaning or replacement. The Wethead RT is a pain to get to but I didn't find it that bad and the thing was clean they must have the air intake in a much better spot because I'm not seeing the bugs or dust... It's good to take the bike apart every now and then you learn things that may come in handy another time. Someone else mention it, I agree it's very easy compared to the LT. No way to learn all those screws, if you want to mess with someone throw in an extra... Tech Days are fun Jay Edited December 30, 2016 by strataj Link to comment
Bill_Walker Posted December 31, 2016 Share Posted December 31, 2016 ...Below the filter is a cavern that could have been used to increase the fuel capacity by at least 2 gallons. Or perhaps configured as a center glove box big enough to hold an actual pair of gloves? Airbox volume matters to proper running of the bike (and to emissions and noise control). It's there for a reason. See here (Wikipedia link). Link to comment
