Whip Posted December 26, 2016 Share Posted December 26, 2016 That bar does not look comfortable. Did BMW offer a pad? What did it look like and where can I find one? I can make one if I have to. Link to comment
szurszewski Posted December 26, 2016 Share Posted December 26, 2016 Should probably have Louise pilot and you ride back there a few hundred miles before you judge it uncomfortable - could be great ...as to your question, having never been able to actual end up with a GS even though I set out to buy one twice now, I don't have a clue - sorry! josh Link to comment
Tri750 Posted December 26, 2016 Share Posted December 26, 2016 They normally had an accessory back pad for most all the tail trunks. Normally thin, injected foam . The parts fiche doesn't show one available for the 1150 Adv. tho. Odd. I used to install all the accessories the service dept. didn't want to mess with and I was pretty sure one was offered. Link to comment
dirtrider Posted December 26, 2016 Share Posted December 26, 2016 Afternoon Whip I have seen a number of backrest pads on the old 1100/1150GS but none that I recall were BMW OEM offerings. Most common was the Sargent but IFAIR those needed the Sargent backrest frame to allow the pad install. I have a friend that rode an 1150GS with a similar top case to yours & he used a seat pad with straps through the two forward top loops on the top case (only when he had a passenger on board). You might try E-Bay & use the search words sissy bar backrest or sissy bar pad. Or, if you live close to a Harley dealer they usually have a number of smaller thinner sissy bar backrest pads. If you want BMW then possibly look at a 1200GS aluminum top case back pad (see if it has any chance of lining up on your top case) Link to comment
StuGotz Posted December 26, 2016 Share Posted December 26, 2016 Looks like you've got a decent rack bar to mount to there. I'd fashion my own plate and take it to a local upholsterer and have it covered. This way you have nothing attached to the box and with the box left off you'll still have a back rest there. Good luck. MB> Link to comment
eddd Posted December 27, 2016 Share Posted December 27, 2016 I'm not implying that Louise is old or anything, but this might work. Link to comment
