RTnger Posted November 10, 2016 Share Posted November 10, 2016 Reviews please: thank you Link to comment
KeithK Posted November 10, 2016 Share Posted November 10, 2016 I put the Suburban Machinery lowering peg brackets off my hexhead onto my wethead,fit & work the same as far as I can tell. No issues Keith Link to comment
KSB Posted November 10, 2016 Share Posted November 10, 2016 Knight Design Lowered Footpegs just ordered a set Silver Anodized with Sidetrax Tread; all one piece with springs and pins. These can be ordered in different configurations of finish and tread. About $80 cheaper than Suburban Machinery adapters. Work GREAT. Link to comment
RTinNC Posted November 10, 2016 Share Posted November 10, 2016 Did either of you have to adjust shift lever or brake lever ? Link to comment
KeithK Posted November 10, 2016 Share Posted November 10, 2016 I adjusted my shifter (easy) and my brake. Using all of the brake pushrod available worked just right for me. YMMV Keith Link to comment
hopz Posted November 11, 2016 Share Posted November 11, 2016 Sorry I missed this post earlier.. Yes I use them. They were the first things I installed. No scrapes, no issues at all. More comfort, and I am a short guy. Did not have to adjust the levers... Link to comment
Mike the Ghoul Posted November 12, 2016 Share Posted November 12, 2016 I have the adjustable verholen pegs. For me and the passenger. I liked the adjustable aspect. I knew once I got the correct position I wouldn't move them, but getting them correct in the first place was why I wanted the adjustability. I rode with them a month or so, then adjusted them a little and they are now perfect for me. I didn't change the levers at all. I have no issues with that. I have to bend my ankle a little for shifting but its not a big deal. For the passenger I needed them to raise instead of lower. The back of her knees were hitting the front corner of the cases. Raising her feet/knees eliminated that, and also allows her better leverage to push back when she needs to. She is 5-0. I am 5-8. mike Link to comment
Rob L Posted November 17, 2016 Share Posted November 17, 2016 You can check out this thread about adjustig the brake and shift pedals. http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Main=87615&Number=972894#Post972894 Link to comment
Rossy GlosPolBiker Posted November 21, 2016 Share Posted November 21, 2016 I have just installed these from http://www.nippynormans.com/footpeg-lowering-kits/rider-footpeg-lowering-r1200rt-lc-2014-on They were easy to install and they supplied a brake pedal plate which moved the assembly to the rear and down. I haven't adjusted my gear lever. :-) Link to comment
Gene#3 Posted December 1, 2016 Share Posted December 1, 2016 Did either of you have to adjust shift lever or brake lever ? I just installed the Knight Industries pegs and find my stock shifter and brake pedal just find. I have small feet... if that makes any difference Link to comment
