rocks Posted August 26, 2016 Share Posted August 26, 2016 Quick question... is there any reason a K75 will not operate with out the Instrument cluster? Thinking of going bare bones! Link to comment
StuGotz Posted August 26, 2016 Share Posted August 26, 2016 Three things I'd need: Tach Red light - oil Green light- neutral Just my preference though YMMV MB> Link to comment
Dennis Andress Posted August 26, 2016 Share Posted August 26, 2016 Yeah, there is, but hell if I can remember what. Maybe it's the charging circuit needing the little light bulb. Try it and see... Link to comment
rocks Posted August 27, 2016 Author Share Posted August 27, 2016 Yeah, there is, but hell if I can remember what. Maybe it's the charging circuit needing the little light bulb. Try it and see... Needs some work before I can get it to the point of starting it... not sure its worth doing the work to get it even to that point if it wont work... Hoping someone out there has one and is willing to unplug the cluster and see if it'll run. Thanks again Link to comment
George in VA Posted October 17, 2016 Share Posted October 17, 2016 As mentioned above you will have no charging. Also you will need to make sure your clutch switch works. The starter relay must see a closed through either the clutch switch or neutral light. Link to comment
