PAS Posted August 5, 2016 Share Posted August 5, 2016 Good morning, I have manually bled my (whizzy-servo) brakes and clutch twice in the past 4 years with no problems and its time to do it again. I recently bought a Harbor Freight hand vacuum pump and need some advice. Do I tie the clutch lever back when drawing the fluid thru? Same as the brake lever? Seems strange that I dont know what to do. Never had a vacuum pump before. Link to comment
dirtrider Posted August 5, 2016 Share Posted August 5, 2016 Morning PAS No, on both the brakes & the clutch the lever MUST be all the way out to open the take-up-port hole & allow fluid to flow through the system. Once the lever is pulled (even a little bit) that closes off the reservoir from flowing fluid into the system. Link to comment
PAS Posted August 5, 2016 Author Share Posted August 5, 2016 Thanks D.R.! I was hoping you were online this morning. Link to comment
