Mark C Posted July 31, 2016 Share Posted July 31, 2016 Was searching for heated grips malfunction and now when I try to start bike I get big EWS on gauges. I dis-connected battery and hope after awhile it will re-set. Don't know what the code means? Mark Link to comment
JR356 Posted July 31, 2016 Share Posted July 31, 2016 Possibly antenna ring failure for built in anti theft system. A known problem. Make sure you do not have other chipped ignition keys near the antenna ring that surrounds your ignition switch at the same time as your bike key.i If you have a spare ignition or the emergency key on the same key ring,it will confuse the system and give you the warning. If it will not reset,then antenna ring will need replacement to the later style. There are past posts here and other sites on the web about how to do this. JR356 Link to comment
George S. Posted July 31, 2016 Share Posted July 31, 2016 Isn't that the electronic ring that reads the key to allow it to start the bike? Went bad on my 2011RT and needed a tow to the dealership. EDIT: What JR said! ^^^ Link to comment
Mark C Posted July 31, 2016 Author Share Posted July 31, 2016 I forgot to say, this is a 2009 Link to comment
dirtrider Posted July 31, 2016 Share Posted July 31, 2016 Evening Mark Make sure that you didn't somehow dislodge the antenna ring plug (if it isn't solidly plugged in you will get an EWS & a no-start) There is probably a plastic cover over that connector. Link to comment
Mark C Posted July 31, 2016 Author Share Posted July 31, 2016 Thanks man, that was it, a good push on it and it started ok. Link to comment
mitchntx Posted July 31, 2016 Share Posted July 31, 2016 Sounds like a good candidate for a dose of dielectric grease. Link to comment
Sonor Posted August 1, 2016 Share Posted August 1, 2016 You are lucky, mine turned out to be a brand new computer. $1400 later the bike works again. Link to comment
Mark C Posted August 1, 2016 Author Share Posted August 1, 2016 Sorry to hear, that is a freak-out! Link to comment
