ltljohn Posted May 21, 2016 Share Posted May 21, 2016 Hope someone here can help. I posted on the F650 forum also but too much info is better than none I am working on my wife's 1997 F650ST, I had the battery box out and now I have 3 hoses left. I know that one is the old battery drain, and 1 is the air box drain and should be plugged down by the foot peg. The one that I can not figure out is larger than the other 2 it runs up and across and connects to the crank case on the front right side of the motor. Where does this hose go? Thank in advance for your help. John Link to comment
Stan Walker Posted May 21, 2016 Share Posted May 21, 2016 Where does this hose go? If its the one I'm thinking of it connects on the bottom of the air box. Left front corner. Link to comment
