dougied Posted March 25, 2016 Share Posted March 25, 2016 Hi guys I have another post on going about ABS but I have to take my tank off and have got to a point where there is what looks like a metal tab on a quick release fitting on the fuel line.It pushes in but I cant pull apart the fitting and the pipe am I doing it wrong anyone know, I don't want to break it. I cant see how to put up a pic on here either could someone help with that also I see enter an image but it wants a web page link? Thanks guys Dougie Link to comment
roger 04 rt Posted March 25, 2016 Share Posted March 25, 2016 You have to upload the picture to a photo hosting service and then get the web link from them. Sometimes when you fully depress the QD plunger you have to apply a little force between the two halves to get it started. I put a flat blade screw driver between the halves and GENTLY twist, which gets it started. If it takes anything more than that you may not be fully depressing the plunger. Link to comment
jfremder Posted March 25, 2016 Share Posted March 25, 2016 Push the tab in all the way, very gently twist back and forth slightly while pulling apart to separate the two parts. The plastic fuel line going towards the rear is fragile, be careful. Link to comment
dougied Posted March 25, 2016 Author Share Posted March 25, 2016 Push the tab in all the way, very gently twist back and forth slightly while pulling apart to separate the two parts. The plastic fuel line going towards the rear is fragile, be careful. Nice one pal that worked perfectly for me back and forth did the trick, I,ve heard they break easy and so did not want to force it but hey wonderful now off and waiting on my parts for tue now...Thx , great !! _________________________ Dougie Link to comment
dougied Posted March 25, 2016 Author Share Posted March 25, 2016 Gotcha Roger thanks matey great help I did it before I seen your post but helpful all the same buddy cheers about the help too about how to post a pic I must look into that. You have to upload the picture to a photo hosting service and then get the web link from them. Sometimes when you fully depress the QD plunger you have to apply a little force between the two halves to get it started. I put a flat blade screw driver between the halves and GENTLY twist, which gets it started. If it takes anything more than that you may not be fully depressing the plunger. Link to comment
dirtrider Posted March 25, 2016 Share Posted March 25, 2016 Afternoon Dougie Be sure to hold the metal tab down all the way through the take apart & put back together. If you don't hold the metal tab down as the quick disconnect slides apart or back together you can easily nick the internal "O" ring therefore getting a fuel leak at a future time. Link to comment
Shiny Side Up Posted March 25, 2016 Share Posted March 25, 2016 Afternoon Dougie Be sure to hold the metal tab down all the way through the take apart & put back together. If you don't hold the metal tab down as the quick disconnect slides apart or back together you can easily nick the internal "O" ring therefore getting a fuel leak at a future time. I learned that some time ago - don't ask how... Link to comment
