Jim Moore Posted March 24, 2016 Share Posted March 24, 2016 Hi Guys, I may be looking at an R1150RT today. If the owner lets me I'd like to inspect the splines. How much plastic do I need to pull off to remove the starter? Link to comment
kioolt Posted March 24, 2016 Share Posted March 24, 2016 You will need to remove the left side panel. If memory serves me right you would also need to remove the left foot peg plate. Link to comment
dirtrider Posted March 24, 2016 Share Posted March 24, 2016 Morning Jim That isn't a 20 minute job. Basically the belly & L/H side Tupperware need to be removed, then in most cases the L/H foot peg side plate removed including disconnecting shift linkage (don't forget to disconnect battery) If you have a starter that the inner bolt is not too tight then sometimes the starter bolt can be accessed with a ball end socket or double flex joint. That would be some exceptional BMW owner to allow the starter to be removed on a bike that is for sale. Link to comment
Jim Moore Posted March 24, 2016 Author Share Posted March 24, 2016 Blah. Thanks guys. I was hoping it would be quick. Link to comment
AndyS Posted March 24, 2016 Share Posted March 24, 2016 Left hand foot plate can stay in place. The starter motor can be manipulated out of that gap. As DR says, a wobbly drive is a great help for getting to that lower inboard bolt. Link to comment
roger 04 rt Posted March 24, 2016 Share Posted March 24, 2016 I've done this half a dozen times now. If you stay focused, 10 minutes to remove left side plastic 10 minutes to disconnect battery ground; remove ball-end of shift linkage at shift lever (lower ball), a small pin at ball, pop ball joint apart, keep an eye on the grease felt washer; remove starter (universal joint & 6-8" extension for hex drive socket) 10 minutes to inspect clutch 20 minutes to get everything back together Remember to reset the TPS (key on, rotate throttle twice, etc.) Link to comment
greiffster Posted March 24, 2016 Share Posted March 24, 2016 I agree with Roger above ^^^. I removed mine several times to clean the starter bendix and once to check the splines. I can do the whole thing now in under an hour. Link to comment
