RPG Posted March 18, 2016 Share Posted March 18, 2016 I'm helping a buddy this weekend with new tires and I am guessing we need a special took to remove the front axle. Does anyone know which to get? thanks, RPG Link to comment
lkraus Posted March 18, 2016 Share Posted March 18, 2016 Some spark plug sockets will work if you reverse them and add an extension. Look for one with a 22mm (7/8") hex on top. Otherwise, you can purchase one, just search Google for "bmw 22mm axle tool". Lots of options for $10-$30. Link to comment
LBump Posted March 18, 2016 Share Posted March 18, 2016 Marc Parnes Products Or, anything that does the job... Good Luck. Link to comment
NickInSac Posted March 18, 2016 Share Posted March 18, 2016 There should be one in the tool kit... if he has it. Link to comment
RPG Posted March 18, 2016 Author Share Posted March 18, 2016 thanks everyone. Nope, he doesn't have any kind of toolkit. Link to comment
Ken S Posted March 18, 2016 Share Posted March 18, 2016 I got this one from Amazon: link Link to comment
dirtrider Posted March 19, 2016 Share Posted March 19, 2016 Morning Rick It sounds like you need it this weekend so don't have time to order one. A 7/8" OD Coupling Nut from Lowes or Home Depot works good (basically just a long 7/8" OD nut) Or a long 7/8" OD lug nut from an auto part store will work. You can even use a use a 7/8" hexhead bolt with a nut screwed on then the bolt end peened or welded to keep the nut tight (basically a double 7/8" OD nut. Or 7/8" headed hexhead bolt with a hole drilled in the threaded end to allow a screwdriver to go through the hole & turn the axle out. Or just use a 7/8" headed hexhead bolt with a pair or vice grips on the bolt threads. About anything that is hex, 7/8" OD, & long enough to go into the axle end & have enough sticking out to get a wrench on the part sticking out. I carry a 7/8" coupling nut in my 1200 bikes that has a hole drilled in it cross ways so all I need to do is stick a screw driver, or extension, or rod, or anything into the hole to remove the front axle (works like the old 1100/1150 spark plug wrench) Link to comment
PadG Posted March 19, 2016 Share Posted March 19, 2016 Morning Rick It sounds like you need it this weekend so don't have time to order one. A 7/8" OD Coupling Nut from Lowes or Home Depot works good (basically just a long 7/8" OD nut) Or a long 7/8" OD lug nut from an auto part store will work. You can even use a use a 7/8" hexhead bolt with a nut screwed on then the bolt end peened or welded to keep the nut tight (basically a double 7/8" OD nut. Or 7/8" headed hexhead bolt with a hole drilled in the threaded end to allow a screwdriver to go through the hole & turn the axle out. Or just use a 7/8" headed hexhead bolt with a pair or vice grips on the bolt threads. About anything that is hex, 7/8" OD, & long enough to go into the axle end & have enough sticking out to get a wrench on the part sticking out. I carry a 7/8" coupling nut in my 1200 bikes that has a hole drilled in it cross ways so all I need to do is stick a screw driver, or extension, or rod, or anything into the hole to remove the front axle (works like the old 1100/1150 spark plug wrench) Yep! That is exactly what I had in my tool-roll for my prior '07 RT! I went one step further and thread in a standard bolt, with generous amount of JB Weld in the thread (I wish that I owned a welder!) to give me a smaller hex. size that I could grab with a standard socket or wrench. Link to comment
