Jharpphoto Posted March 1, 2016 Share Posted March 1, 2016 I have'nt ridden my 2012 RT very much this winter but I've had a couple of days in the past week where it was nice enough to merit a little spin. Today while checking out my bike I noticed this little seepage on my unwashed steed. What do I have here? I have'nt seen it leak here before in the past year I've had it. Link to comment
dirtrider Posted March 1, 2016 Share Posted March 1, 2016 Afternoon Jharpphoto There is an oil seal under that plastic ring & that seal looks to be seeping a little. A little seepage is no big deal BUT there isn't a good way (re easy way) to check the final drive fluid level. In any case that seal is relatively easy to replace-- just gently pry that plastic ring off the spool then drill a couple of VERY SHALLOW (just through the outer seal metal) holes in the seal then screw in a couple of sheet metal screws & CAREFULLY pull/pry the old seal out. (try not to damage the removed seal) (some gear oil will probably run out) Then install the new seal using the old seal as a seal driver. Then snap the plastic ring back on. Then drain & refill the final drive. Link to comment
Jharpphoto Posted March 1, 2016 Author Share Posted March 1, 2016 great advice as always DR. Thanks for your help. Afternoon Jharpphoto There is an oil seal under that plastic ring & that seal looks to be seeping a little. A little seepage is no big deal BUT there isn't a good way (re easy way) to check the final drive fluid level. In any case that seal is relatively easy to replace-- just gently pry that plastic ring off the spool then drill a couple of VERY SHALLOW (just through the outer seal metal) holes in the seal then screw in a couple of sheet metal screws & CAREFULLY pull/pry the old seal out. (try not to damage the removed seal) (some gear oil will probably run out) Then install the new seal using the old seal as a seal driver. Then snap the plastic ring back on. Then drain & refill the final drive. Link to comment
Jharpphoto Posted March 2, 2016 Author Share Posted March 2, 2016 will I need to replace the final drive oil after replacing this seal? If so is there a vid someone can link for instructional purposes? Link to comment
dirtrider Posted March 3, 2016 Share Posted March 3, 2016 will I need to replace the final drive oil after replacing this seal? If so is there a vid someone can link for instructional purposes? Morning Jharpphoto Yes, you really should drain & replace the gear oil after a seal replacement as you really have no idea of how much oil was lost to seal leakage & seal replacement. (personally I usually drain the final drive before even installing the new seal) As for a video?-- I have no idea, but a good possibility there probably is somewhere. Link to comment
stevenh Posted March 8, 2016 Share Posted March 8, 2016 Wouldn't that be covered under warranty? Link to comment
