Rumbles Posted February 22, 2016 Share Posted February 22, 2016 This could be a dumb question but I would rather ask than cause any damage to the bike. I want to add a battery tender to my new to me 1994 R1100RS , usually this small amount of charging is ok with the battery hooked into the bike's electrical system but want to make sure this is acceptable to do on my model bike. Thoughts? Link to comment
JR356 Posted February 24, 2016 Share Posted February 24, 2016 No problem using Battery Tender on your bike. JR356 Link to comment
Rumbles Posted February 24, 2016 Author Share Posted February 24, 2016 No problem using Battery Tender on your bike. JR356 Ok thank you, just wanted to make sure. Link to comment
gordiet Posted February 24, 2016 Share Posted February 24, 2016 I've been using BTs on my BMWs for years with 0 problems. GT Link to comment
BNA Pete Posted February 24, 2016 Share Posted February 24, 2016 Just make sure you use a battery tender, not just a trickle charger. A proper battery tender monitors the voltage, charges when it drops below a certain point and stops when it gets above a certain point. An always-on charger can burn out your battery. Link to comment
mwood7800 Posted February 24, 2016 Share Posted February 24, 2016 Your battery will last longer without a tender unless you get a good tender, don't go cheap Link to comment
gordiet Posted February 25, 2016 Share Posted February 25, 2016 Your battery will last longer without a tender unless you get a good tender, don't go cheap Buy the real thing. GT Link to comment
