vfred Posted February 7, 2016 Share Posted February 7, 2016 Attempted to change a burnt out headlight bulb and the little black plastic power plug disintegrated. Plugged the spade connectors to the bulb without the plastic holder and now neither low beams work. Does the plastic housing do something? The plastic plugs on both low beams have broken. Would be grateful for any guidance on what to do now. Link to comment
vfred Posted February 7, 2016 Author Share Posted February 7, 2016 found a bad connection. Problem solved. thanks Link to comment
Dann Posted February 9, 2016 Share Posted February 9, 2016 Glad you found the problem I would suggest to add a heavy duty harness to your H7 connector spades. These are ceramic and won't fall apart like the OEM plastic ones Link to comment
